Topic: Rotary switch? (Read 5 times) previous topic - next topic
Rotary switch?
Yahoo Message Number: 2948
Technically-challenged here...what does "isolating the coach batteries" mean and/or do?
Bruce B 2002 26.5 MB owner-wannabe Bradenton FL
Rotary switch?
Yahoo Message Number: 2952
Its just a master battery switch. Any lead-acid battery will be severly degraded if it is left discharged for extended period of times. If you are storing your RV for a few months where it will receive no charging current, this switch cuts off everything, including all the very small drains from the various monitor/alarm units. These units (LP gas, carbon CO, fire) draw a few thousanths of an amp each. Small, but sufficinent to discharge even a 220 amper-hour LD coach battery over a few months. The switch shuts everything off.
Linley Gumm
Rotary switch?
Yahoo Message Number: 2954
"These units (LP gas, carbon CO, fire) draw a few thousanths of an amp each..."
Some draw considerably more - especially LP detectors and CO detectors with displays. It is not unusual to find 1 Amp or more of phantom loading.
Older models did not come with this array of detectors, and I have resisted buying any for ours that don't use self-contained batteries.
