26.5MB Black Water Connection Height March 18, 2001, 09:47:07 am Yahoo Message Number: 2692Can one of the owners of the 26.5MB tell me the height of the black water connection from the ground, and also the approximate height of the tank?Iam trying to plan a connection to my sewer system using the Sewer Solution, while I await my new unit scheduled for early June.Any help would be appreciated.Clarence
26.5MB Black Water Connection Height Reply #1 – March 18, 2001, 05:52:13 pm Yahoo Message Number: 2699Clarence:As to the height of the MB sewer connection - it is angled downward, but the center of the cap is 13 inches from the ground.The depth of the tank is 11 1/4 inches, but in rereading your post I think you wanted the top of the tank to the ground and I did not measure that, but estimate it to be about 27 inches above the ground, give or take 2 inches.If the Sewer solution will not do it, I recommend you look at the Poop Out Pump, which is a macerator pump attached to the dump connection. See [url=http://www.lazydazeowners.com/[url=http://shrewsburyservices.homestead.com/. It works great, but you have to do the wiring. I used 6 gage wires to two battery clamps (it draws quite a current) and wired a fuse and switch into the circuit.Good luckGus Weber
