wood framing and new 350 engines March 13, 2001, 05:30:47 pm Yahoo Message Number: 2603does lazy days still make the interior frame out of wood ?. if so there probley the last to do so. is wood framing beter? thanks for your replys and safe travels. also if needed you can get a brand new (not rebuilt) 350 chev long block at cormier chev in wilmington ca.
wood framing and new 350 engines Reply #1 – March 13, 2001, 06:13:06 pm Yahoo Message Number: 2604Lazy Daze still uses wood framing, fiberglas insulation in walls and ceiling, and aluminum and fiberglas skin over thin wood panelling.This method is time-proven and holds no surprises such as tend to pop-up in new-tech methods. It is reliable when executed well, which LD does.In addition, there are heavy-gauge steel gussets that run all along the side seams with the roof and front and rear caps.Steve
