Power Window/Doorlock Bezel June 24, 2003, 10:50:30 pm Yahoo Message Number: 23755Recently I mentioned I had power window failure on the passenger side and found it was nothing more that a loose wire in the master control on the driver's side. To access the wiring harness, you have to pop the bezel (cover) that holds the power window and doorlock controls. If you ever do this, it opens from the back side (towards the rear of the coach)by inserting a small screwdriver and pushing the metal flange in that holds it tight. I popped it from the front and broke off the plastic lip on the bezel that snugs under the front rim to hold the bezel in. Fortunately, Ford replaced the part under warranty and it was simple to replace.Chris Horst
