Brake Buddy answer (Chris) June 17, 2003, 10:51:47 pm Yahoo Message Number: 23528Tom, what sensitivity setting do you use on the Brake Buddy to achieve your braking pattern? Chris, The center position between + & -. My BB is an old model, and it may not correlate to yours. Tom.
Re: Brake Buddy answer (Chris) Reply #1 – June 17, 2003, 11:27:01 pm Yahoo Message Number: 23530Tom, what sensitivity setting do you use on the Brake Buddy to achieve your braking pattern? Chris, The center position between + & -. My BB is an old model, and it may not correlate to yours. Tom.PS. Your toad will also require different settings compared to others. The only good way to set your Brake Buddy (IMO)is behind your LD out on a lonely stretch where you can try various sensitivities and pressure settings. Then mark them with a laundry marker or whatever works best for you.
