Topic: Water Tank Location (Read 5 times) previous topic - next topic
Water Tank Location
Yahoo Message Number: 23461
There have been a few posts recently about the location of the water tank in the 26.5' LD's.  It seems that the tank is located in some locations that are inconvenient for regular access (under the couch, under the stove, etc.).  This leads me to two questions:
1.)  Given the tank's location, is it impractical to install one  filter to filter all of the water going out of the tank?
2.)  How do you drain the tank in winter?
Thanks,
Dave
Re: Water Tank Location
Yahoo Message Number: 23463
Filtering is usually done BEFORE the water enters the tank, or only for drinking as a separate feed. Most who filter all their water do so when they have hookups, i.e. they use the city water connection.
All LD have a convenient and effective gravity-fed drain integral to the design. Small pools of water in the bottom will not cause a problem if they freeze. Evacuating the plumbing is of more concern.
