More water pump and tank questions June 15, 2003, 01:34:55 pm Yahoo Message Number: 23427I've been checking out our new 97 26.5 MB to find all the tanks, etc. I thought I found the water tank, but after careful consideration and before I took out the plug(thank goodness)decided it was the gas tank! The other two tanks I can see from underneath are the grey and black water tanks. Where is the water tank? I found the faucet drain handle, but not the tank. From the RB discussions, it sounds like it might be under a couch somewhere. Would a MB owner who tell me where we could find it? Also can hear the water pump(barely)and know it works, but likewise can not find it. Sounds like it might be in the kitchen area somewhere, but I'm not sure. Where is the access to this located? Saw Andy's new door to access his pump on the TK, but our kitchen appears to be laid out differently. Is there a maintenance book that we are missing? None of the this info appears in our LD manual. Thanks for any help. Mary Tribbett
Re: More water pump and tank questions Reply #1 – June 15, 2003, 02:11:00 pm Yahoo Message Number: 23430In the MB, the water tank is under the stove. Pull out the lower drawer to the right of the sink and you can see it. You want it there so it can use the warmth of the coach to prevent freezing.The water pump is behind a panel under the sink - the one running athwartship at right angles to the power panel under the door to under-sink storage. It has six screws to remove it and it gives access to the water pump. I would disconnect the battery before doing anything back there so you don't accidentally create a short on the back of the power panel.Good luckGus Weber QuoteI've been checking out our new 97 26.5 MB to find all the tanks, etc. QuoteI thought I found the water tank, but after careful consideration and before I took out the plug(thank goodness)decided it was the gas tank! QuoteThe other two tanks I can see from underneath are the grey and black water tanks. Where is the water tank? I found the faucet drain handle, Quotebut not the tank. From the RB discussions, it sounds like it might be under a couch somewhere. Would a MB owner who tell me where we could find it? Also can hear the water pump(barely)and know it works, but likewise can not find it. Sounds like it might be in the kitchen area somewhere, but I'm not sure. Where is the access to this located? Saw Andy's new door to access his pump on the TK, but our kitchen appears to be laid out differently. Is there a maintenance book that we are missing? None of the this info appears in our LD manual. Thanks for any help. Mary Tribbett
