Topic: Tires (Read 9 times) previous topic - next topic
Tires
Yahoo Message Number: 1977
My 1985 Dodge chassied LD says not to use Radial tires on this motorhome. Seeing as how technology has changed a lot since then does anyone know if this is still true? I would like to eleminate the thump that goes with bais ply tires. Any reccomendations? Thanks
Bruce
Tires
Yahoo Message Number: 1978
Our first Lazydaze was a 79 on a Dodge chassis, it had 8:25 x 16.5 bias ply tires & I put 8:75 x 16.5 radials on it. The clearance was fine in the fender wells & between the duals & it worked great. I think you need to check the wheels to make sure they are made for radials as the older ones weren't . I was lucky mine had the radial designation on them.
