Topic: Any LD amateur astronomy buffs out there? (Read 4 times) previous topic - next topic
Yahoo Message Number: 20299
If so... I've got a few questions about making LD interior lights "night vision" compatible when necessary.
- David
Re: Any LD amateur astronomy buffs out there?
Yahoo Message Number: 20300
- David
Wouldn't call us 'buffs', but we often cart along my wife's Astroscan 2000. Not sure what you mean about the interior lights, though - all our gazing is done outdoors, where an interior light is not an issue.
If you are in close quarters at a meet, you might try using flashlights inside with red LED's. For serious conversions, there are red LED 12V bulb replacements that should fit some fixtures.
Yahoo Message Number: 20312
"Do you know a source for those 12V red LED bulbs? I've looked around, but so far no luck."
David
 I saw a side clearance light at West Marine that may be just what you want.
Check the below site. I have listed several parts numbers that you should look at.  Good luck.
http://www.westmarine.com/
PN  3683919 3683927 141916 141924
Yahoo Message Number: 20345
Thanks for the suggestion, Larry, but I checked out the site and those numbers, and they are not what is needed.
However... I just got a Crutchfield catalog and saw what I THINK might be the answer. They have Red 12V bulbs
Yahoo Message Number: 20347
"I just got a Crutchfield catalog and saw what I THINK might be the answer. They have Red 12V bulbs in these formats: 1156 and 1157. Are either of these the type of incandescent bulb that LD uses?"
David
LD uses an 1141 bulb in the interior fixtures. They use a clearance light, like the one I pointed out, in the cab, one on each side.
 If you do a Google search for LED bulbs you will find many suppliers of LED automotive bulbs.
My brother and I spent many nights at Mt. Pinos star gazing and taking time lapse photos through a home made 6" reflector and later a Celestron.
Marriage kind of got in the way. I still miss the good times.
Be patient, November will eventually come and your new LD will show up.
Yahoo Message Number: 20348
Thanks, Larry. I will follow through on this. Obviously, I have plenty of time.
- David
