More improvements posted. March 04, 2003, 06:00:37 pm Yahoo Message Number: 19494I have added the following albums to my photo site at: http://photos.yahoo.com/lw5315usHolding tank transfer pump Macerator pumpA posting at; http://groups.yahoo.com/group/LD_Enhancements provides details.Have you started your own photo site? It is easy to do with Yahoo. Go to http://photos.yahoo.com/ and sign up. There has got to be others out there who actively improve their LDs. Lets see what you are doing. Another good reason for doing this is that the photo base on this website is just about full. It is time for you to start removing your old, outdated photos.I have recently gone through my photo site and cleaned things up a bit. A cold rainy night curtailed all construction efforts so I had a chance to utilize a T-1 line at 2:00AM. Things move very quickly at that hour, even Yahoo is fast. I have tried to clarify things and to add more photos. This is about as close to my own website as I'm going to get for the time being so I'm attempting to make it work a little better.As usual, if you have questions or need higher resolution photos, just askLarry
Re: More improvements posted. Reply #1 – March 04, 2003, 09:56:01 pm Yahoo Message Number: 19497Larry, I think that you may have the only LD that has appreciated in value! Those are great enhancements that you have made to your coach.You should let Lazy Daze know about the site so they can consider some of these enhancements for future standard options (ha, as if they are looking to add options . In fact, I will suggest that they take a look when I pick up my LD in a couple of months.thanks for sharing,Mike S.
Re: More improvements posted. Reply #2 – March 05, 2003, 06:39:55 pm Yahoo Message Number: 19525Larry, Those are really excellent ideas, the gray water tank easily fills up so fast. Can the water go without the pump?Edd
Re: More improvements posted. Reply #3 – March 05, 2003, 10:23:55 pm Yahoo Message Number: 19546"the gray water tank easily fills up so fast. Can the water go without the pump?"EddI'm not sure what you are asking. Gravity flow from the gray water tank to the black is not possible since the black water tank sits higher in the frame than the gray water tank. Siphoning through the pump is not possible due to the air gap in the vent pipe, which forms an extremely effective backflow/anti-siphoning device . The water in dumped into the black water tank vent two feet above the tank. The bottom line is you must have a pump to make this system work.Larry
Re: More improvements posted. Reply #4 – March 06, 2003, 03:35:19 pm Yahoo Message Number: 19567The water in Quotedumped into the black water tank vent two feet above the tank. The bottom line is you must have a pump to make this system work. Larry, I got it, now I have to look underneath to check if its doable in my 26.5MB. But first I'll do the fishing pole storage, then the no fuss flush....etc. Thanks again,Edd
Re: More improvements posted. Reply #5 – March 07, 2003, 09:28:41 am Yahoo Message Number: 19593QuoteI have added the following albums to my photo site at: http://photos.yahoo.com/lw5315us Larry, Why don't you put all your LD photos into 1 album. Makes for MUCH easier viewing or slideshow. My .02c worth Dee
Re: More improvements posted. Reply #6 – March 07, 2003, 10:12:33 am Yahoo Message Number: 19598Dee I'm sorry that the slide show feature doesn't work. I have everything broken down into individual albums to make it manageable for me. Yahoo photos is not the easiest thing to work with as is. When working on albums, it sometimes does some strange things that can take a bit of time to fix. One giant album would make it almost impossible to quickly find anything or to modify. Imagine if this website's photo file was just one album instead of the 50 or so albums. Same situation. Multiple files does make it faster for you to find a particular file.Larry
