Topic: dinette length in 26.5 MB - couch (Read 7 times) previous topic - next topic
Yahoo Message Number: 1631
Since you didn't get an answer yet, I'll chime in on this.
Ours is the 22' front lounge with that arrangement, and the bed pulls out in increments that will reach all the way to the chairs, so it is quite wide. With the end bolsters removed, it is long enough for some 6-footers who have used it, and quite comfortable and flat.
What does not work well in our model is using the bed fully extended AND the cabover bunk - not a problem in the rear-lounge models. The nice thing for us is that you can pull out the bed to a narrow-double width, and still get by between the chairs and the bed (and fit the ladder in).
I
have tried the couches in most other brands, and most are the Flexsteel model that is easy to convert, but is thinly padded, lumpy, short and narrow. Since LD makes its own furniture, they have integrated a much better solution.
Yahoo Message Number: 1707
Did you measure both sides? We have a 23 1/2 RK and I'm 6 ft. tall. I sleep (very comfortably) on the right side seat/bed. The other side is a few inches shorter.
