Topic: 1993 Mid Bath  (Read 152 times) previous topic - next topic
1993 Mid Bath
I believe my seals around my 3 back windows are shot. I am having some leaking in rainstorms. I want to have the seals replaced- Im looking for suggestions on what others did to get these seals replaced, What type of shop to go to. The windows are in great shape.
I tried using our search - couldnt find any info for me . Thanks in advance for your help
1993 MB
2006 Honda CRV
Re: 1993 Mid Bath
 A better description of the problem is needed.
Are the leaks in the exterior window frames, is the water coming in around the windows or through the rubber sealing the glass to the frames?
The manufacturer of your LD's windows, Hehr, has been out of business for many years, you will probably be better off resealing what you have. Even in the offhand chance the seals are available, it is a huge job to remove the windows without damage.
Re: 1993 Mid Bath
I know of one former LD owner who had a similar situation with water leaking through the rear window seals.   His solution was to lift the edges of the seals and squeeze window sealant beneath the full length of the seal.  As I recall, he used masking tape to help control the sealant.   Hope this helps.
