Topic: Water heater drain plug wrench (Read 261 times) previous topic - next topic
It is recommended that you flush your water heater tank at least annually. This has been a pain in the… knuckles due to the limited access to the plastic drain plug using a box or open-end wrench. I found that this slim profile ratcheting wrench makes the job much easier, and shouldn't round off the hex-head corners like an open-end wrench can. It is $15.29 on Amazon.
TOOLGUARDS 15/16" Slim Profile Ratcheting Wrench
2013 27’ Mid-Bath
2005 Honda CR-V
Re: Water heater drain plug wrench
I wasn't sure by looking that a socket and extension would work on the water heater drain plug due to the tight space. Does it have to be a thin-walled socket? I can dedicate the ratchet wrench to the water heater drain plug and store it right there behind the water heater access hatch, to keep it handy. I don't know if the flush nozzle would fit there also. The socket is as low as $6 on Amazon, and the wrench is $16. For anyone that doesn't have a flush tool, a link follows.
RV water heater tank rinser
2013 27’ Mid-Bath
2005 Honda CR-V
I just use a standard 15/16 inch wrench to remove the plug. I did bend the shields a bit to give me more room. Maybe not ideal but it works. I keep several extra plastic plugs in the RV in case needed.
Maybe the water here, and also from other surrounding areas in southern Ca. isn't very hard, but I've almost never had any white debris come out of my water heater.  I've posted before, (pictures too) of a drain line with 3/8" valve attached to my heater drain line that makes it easy to drain.  Water Heater Access on 24 TK
   Presently I have a vinyl line (sort of permanently) attached.)  I was working on my tank/pump to install a 'T' for a water filtration add on, and encountered multiple issues with now hard to find PEX A fittings. I did manage to install a high quality, small and certified water safe, 1/2" valve on my water tank. I was also working on the water line to my toilet, solved for now.  Parker Liquifit Par-Barb Valve Union Connector - 1/2 ID Barb x 1/2 ID Barb –...   That valve inserts into the 'hose' type of line that LD used in many tank to water pump plumbing.
   But I had to drain the water heater multiple times, sometimes 2-3 times a day. Using a 5 gallon bucket I could save most of that water. My container plants appreciated that.
   I mostly do water heat for dishwashing, and shower duty, but leave it off unless I anticipate needing hot water.
RonB
The amount of white calcium deposits removed depends on the water used and how long it has been since the last flush.
Sometimes the driveway looks like a hailstorm came by. Using a flexible water heater cleaning tool, I aggressively work the flexible dtubel in and out of the drain hole, trying to scour as much of the tank's interior as possible.
Since we are on the road for three to four months a year, who knows how much dissolved minerals we pick up using the local waters?
