Topic: Solar install - batteries & inverter placement (Read 498 times) previous topic - next topic
We're planning on heading out to Q next week to have Discount Solar install a system for us on our "new-to-us" 2013 27'RK.  We're having them install 4-200 watt panels on the roof (will remove the antennae & satellite dish), 2-200 Ah lithiums and a 2K Xantrex inverter.  They did a great job on our 24'TK 5 years ago.
My question to y'all is, where to locate the batteries, controller and inverter?
We will eliminate the AGM's in the battery compartment that unfortunately, is not big enough for the Lithium batts... "new"storage box, eh?
On the drivers side, forward, there is a vertical compartment that could most likely house the batts, controller & inverter.  In the kitchen, one of the bench seat cushions can be removed opening up that space.  Passenger side has two forward compartments that could be used but, seems a bit more difficult to access.
Seems to me the best location would be the vertical compartment, behind the drivers seat or in the kitchen.  My question has to do with weight that would be added drivers side next to the fresh water tank or on the rear of the coach across from the water heater...
Has anyone with the RK layout installed a solar system such as this?  Any insights or recommendations?
TIA!
Bill
Zia, our 2013 27’ RK
2006 24' TK, sold
SKP Lifetime member #105622
Land of Enchantment
Re: Solar install - batteries & inverter placement
If I remember correctly, the battery box is located under the kitchen sink, and there is storage under one of the dinette seats. There are no large exterior compartments nearby. The entire battery bank must be kept together to keep the battery cables approximately the same length.
The rear dinette is too far away from the Factory battery box for proper installation and there is no direct passage to run the cables under the floor.
Is there storage under one of the front seats?
Yes, outside forward compartment, drivers side (under the sofa next to the water tank).  That compartment appears large enough to accommodate batteries & inverter.    Outside access only.  The compartment where the batteries are now isn’t large enough for the lithium batteries.  My only concern at this point is adding the weight of the lithium’s, charge controller and inverter close to the water tank…
2006 24' TK, sold
Land of Enchantment
Disclaimer: I know nothing of your model or layout, so the following might be nonsense in your case.  ;D
However, having just removed the battery box from my midbath - I can advise on two things I discovered. Whether they apply to other models/battery boxes like yours, I don't know.
First up - simply removing the sliding battery tray opens the box up by a surprising amount in all dimensions. You might find a pair of 200AH that fit in there with it removed. You can get creative with dimensions, as most lithiums can be mounted in any orientation. You should be able to measure the potential space savings pretty easily.
Second, if removing the battery box entirely is an option, and the area surrounding it is anything like the midbath - that frees up a ton of space. I could have fit 2 x 300AH in the battery box location in the midbath once it was removed, as there was 4-8" of unusable space around the battery box edges and the cavity is was installed in. Note on this - removing the battery box is not for the faint of heart on the midbath. It's not difficult, but very time consuming and laborious.
And of course, both of the above potential solutions don't address where to put all the other components - just battery replacement.
2002 26.5 MB
Previous: 2011 27 RB, 2005 24 TK
Thanks, Will and Larry.  I'm hoping that if nothing else, clearing out the "old" battery box will open up for some of the "lost" storage used for the new assembly... If I could get the lithiums in there and if the charge controller & inverter don't necessarily have to be in close proximity to the batteries, then that may indeed be an option.
I'm sure the folks at Discount Solar know their stuff in this regard, I'm just trying to be of some help to them in getting this done.  With my 24', it was relatively easy and straight forward.  This layout doesn't seem as simple.  Tho' I could be making things more difficult that they need to be...
Wouldn't be the first time... 🙄
2006 24' TK, sold
Land of Enchantment
The inverter should be located as close to the battery bank as possible.
jor
09 27' MB
10  Suby Forester
Bill, have fun at Q and be sure to follow up with how your install goes!
