Topic: Electrical Upgrade Project (Read 1694 times) previous topic - next topic
I've touched on the beginnings of this project in a couple other threads, but I'll document the process from beginning to end here. Plans are mostly finalized, but could certainly change along the way. And, thanks to all who have blazed this path ahead of me...plenty of the decisions made so far were based on feedback found at this great site. Trust I'll not be shy about posing questions to the many experienced participants here as this project moves forward.
The rig: 2002 26.5 Mid Bath
I'll cover some of these in more detail as they are installed, but the basics:
Several of the components are being repurposed from a Transit van recently sold, and as luck would have it they appear to be a perfect match for the LD midbath layout and our known needs. Specifically, the older Multiplus inverter will fit nicely in the space freed up by the original battery box removal, and the long, narrow Lifeblue 200's are a perfect fit for the compartment below the battery box. The length of these batteries is literally the exact depth of that compartment floor.
This is my fourth Victron/lithium installation, having worked with AM Solar on the previous three when they were still in business. They did all of one installation, the solar on another and only provided parts for the third. Still, even though I have one complete installation under my belt - this is my first motorhome installation so there are a few new bits to research and understand. And, I'll no longer have the safety blanket of AM Solar now that they are out of business. They sure proved their worth on previous installations, providing valuable info and advice as I worked my way through those projects.
Charging of the bank via a secondary alternator is new to me, as is incorporating the Onan generator into the mix. That last bit, though - my hope is, to never need the Onan again. I'll keep it in the mix for now, but after a year or so if we find it is never needed - it will be removed. What, if anything will take its place I'm not sure...but the one thing I've found limits our extended boondocking more than anything is water. Perhaps an auxiliary tank will go in its place, but that's a decision and project for the future.
Let the fun begin.
2002 26.5 MB
Previous: 2011 27 RB, 2005 24 TK
Re: Electrical Upgrade Project
Location, location, location...it's not just for real estate.
Having done my last Victron/lithium installation in a van, my appreciation for squeezing things into tight spaces is fresh in my mind. Still, storage space will be lost. We read posts here about potential locations in the mid-baths, then analyzed our space preferences based on how we used our last two LD's. In short, it boiled down to whether we preferred giving up internal or external storage - and external got the axe. Batteries will go in the compartment below the original battery box and the bulk of new components will go where the original battery box was. Both the drawer and cabinet space beneath the fridge will remain 100% usable.
Here's the gutted battery box location, looking through to the storage space below the fridge. Space is actually gained removing the battery box, as there was a small amount of unusable space above and to the sides of the battery box.
And yes...still plenty of wiring cleanup and identification to do.
Here's a picture of the planned location for the largest component (other than batteries), the Multiplus inverter/charger. I'll be building a simple support frame out of 80/20 to hang it from, it will sit just high enough in this location to allow the 4/0 wires to exit. The 80/20 frame will also support the back of the drawer mount shown in the picture, as well as a mounting board for various other components accessible through the original battery door. Having monitored temps in the previous three installations, I believe there will be adequate airflow around everything once installed, but if not - it's trivial to wire up a couple fans in this location, triggering them off the Cerbo GX relays as needed.
Lastly, the lithium location with 3x200AH Lifeblues in place. As mentioned previously, these fit like a glove. There's actually enough room to put in a fourth battery for a total of 800AH, and I do have one more. However, that would require opening up a large hole in the floor above this compartment so batteries could be dropped in from above. As it is now, the batteries need to be slid into the lower compartment on edge, as they are too tall to go in upright. Even though the footprint of the compartment could hold a fourth battery, it's not possible to slide a fourth one in on edge then turn it upright through the small door.
2002 26.5 MB
Interesting. Removing the battery box really gives you a lot of space for components. What is the cable path from the old battery compartment to the compartment below?
A hole will need to be drilled between the two to pass two 4/0 cables. Doesn't look to be a big deal, I can see what I'm in for looking at the existing hole that the water tank drain pipe drops through.
I've yet to decide whether I'll put the main 400A battery bank fuse and disconnect switch in the lower cabinet with the batteries, or up above with the inverter and other components. The fuse should be as close as possible to the battery bank, but we're only talking an additional 8-10" if I put it up by the inverter. I'll see how it lays out and decide.
2002 26.5 MB
Removing the battery box can be a PIA and worth the effort in an MB. It provides a lot more room.
Have you considered how hot the batteries may get in the lower compartment? Lithium batteries automatic shut off when they exceed 135 degrees. You may want to provide ventilation for summer usage..
When traveling in the summer heat, our lower compartments get very hot after hours on the road from the exhaust heat and heat radiating off the pavement. Most owners locate the lithium batteries in the interior, away from the heat and cold
4/0 cable is hard to bend, using flexible welding cable makes the project a bit easier.
I drilled mine in the forward corner of the battery box compartment when I added a 4th battery. Like you said, no big deal.
I put mine in the upper one. Easier to access than the lower one.
Really enjoy the high res photos.
jor
09 27' MB
10  Suby Forester
Today was mostly more layout planning, and I think I've ID'ed all cables. However, the highlight of my day was an "aha moment"...
It's really been bugging me I couldn't fit the fourth 200AH Lifeblue in the lower compartment. Not only because the space is perfect for four of them, but all four were in the van install these components were removed from. I know the capacity will easily handle a week of our needs (regardless of solar), but also - the previous installation took this capacity into mind with sizing of components and Victron programming.
I mentioned it earlier, but the batteries have to be slid in on their side then turned upright due to the compartment height...and there wasn't enough room to turn the fourth one upright.While staring at the compartment, it occurred to me I could slide a battery all the way aft in the compartment if the the water tank drain pipe wasn't there...and of course, it's just screwed into the valve.  Removed the lower pipe section below the valve, slid a battery all the way over in its place, and that gave enough room to slide the fourth one in and turn it upright. Slid the battery back over and reinstalled the pipe. Bingo!
80/20 framing is up next.
2002 26.5 MB
I'd not thought of that, Larry - thanks for the heads up. All of my other installs have had the lithiums inside and temps were not a problem.
I looked up the BMS specs on the Lifeblues, and they cut off at 149 degrees. Still, cooler is always better. I've seen articles about using temperature probes and the relays on the Victron Cerbo GX to trigger fans - I'll look into that, along with providing ventilation between the lower and upper compartments.
I've a bunch of 4/0 cable from the van install, and all the cables are longer than needed so cutting and putting new ends on will save quite a bit of $$. They are Ancor - marine grade, tinned and a super high conductor count. They are almost as flexible as welding cable, but I think the only place that's going to be an issue in this installation is coming out the bottom of the Multiplus. I've already tested one of them to see what kind of radius is needed, and the Multiplus will sit high enough to easily accommodate it. All the other house component runs are less than 12" and relatively straight.
I'll look into welding cable for the secondary alternator to bus bar connection, though. Flexibility will be key there, plenty of bends along the way.
2002 26.5 MB
When drilling through the floor, the holes are drilled oversize and then a piece of PVC pipe is glued in place, providing a neat passage for wires and cables.
You might consider placing the batteries inside and mounting the inverter and other equipment below. Things should fit both ways.
There's not enough room under the fridge for the batteries I have - not even three of them, much less four. That is, unless I sacrificed all of the storage space below the fridge.
Andy Baird linked to these a while back, and were I needing lithiums I'd seriously consider three of them for their features and form factor. However, while they might fit in the old battery box area - that's nearly $3K for something I already own.
I think there's enough room in the lower compartment to line the bottom with foam insulation under the batteries, and perhaps some thinner insulation could be placed on the sides. I'll check into that as well.
2002 26.5 MB
it would be a healthier environment for the batteries. The overall amount of storage does not change.
Four lithium batteries and associated cabling will weigh well in excess of 100 lbs. I’m curious if there is a recommended weight limit for those lower compartments?
Actually, it's quite a bit more than that. Each 200AH Lifeblue is 58 lbs. There will be a fuse and several feet of 4/0 cable down there too, so probably just under 250 lbs. total.
I've never seen a published weight limit, but I do know we've carried about the same weight in both our previous 27 RB and 24 TK compartments when we owned them. A typical winter trip south had us dedicating a single lower compartment to 200 lbs. of dog food +  several cases of water. Never had an issue. The boxes themselves are pretty substantial, but more importantly they are supported with some pretty stout steel straps. Still...I don't know the answer.
2002 26.5 MB
True regarding the environment, however the flip side is it would be far less healthy for all those expensive Victron components that would be installed down there. And, not only heat - but on previous LD's, I've seen condensation in the lower compartments. I would think batteries are far less impacted by that than inverters, solar charge controllers, the Wakespeed, Cerbo GX etc.
Lastly...I'm gonna pull the old man card. It's WAY more difficult to work in the lower compartment down on the ground, doing everything through its very short door. With batteries, they are in and done in minutes - hopefully never needing significant attention for 7-10 years. With all the components installed through the battery box door, I can sit on a stool and comfortably work on everything.  ;D
Regarding the space, yes - available storage would be more or less equal regardless of location, however we don't want to give up any interior storage space. For us, that's in far shorter supply for our needs than external storage. For those who don't mind losing the space under the fridge, keeping the batteries in that location certainly has its benefits. And of course, many won't need/want the lithium capacity we're installing - so with 200-400AH of lithiums, all would likely fit in the area previously containing the battery box.
I've pretty much decided to do two things to address potential temp issues down below. I verified yesterday there's space on the bottom of the compartment for 2" rigid foam, so I'm going to look into adhering some of that to thin ply as a base for the battery bank. There's not as much room on the side walls or door, but I'll look into adhering something thinner there as well. More importantly though, I am going to design in ventilation controlled by the Cerbo GX. The thought is to cut two additional holes between the interior floor and the compartment, installing two fans - one pushing, one pulling. Triggering them with high and low temp thresholds via the Cerbo should keep the box temps roughly the same as the interior.
2002 26.5 MB
Keeping the batteries happy year-round may require a hybrid system.
If the batteries have Bluetooth, their temps can be monitored, if not, drop a remote temperature probe between two batteries to watch the temps.
For summertime use, adding vents to the exterior door, along with a fan should be better than pushing heat into the already warm interior. I have done this on previous installations. when a large inverter has been installed in the lower compartments..
For wintertime, closing off and insulating the exterior door and opening vents into the interior would help provide heat, possibly with a fan to encourage circulation. I assume the batteries have heaters to keep them warm in very cold conditions. If not equipped with heaters, 12-volt holding tank pads could be used to provide supplemental heat.
It is going to be hard to pump enough heat down into the exterior compartment in adequate quantities to make a significant difference.
To make working on the lower compartment easier, I have lifted the whole RV and placed it on four 12-ton jack stands.
Old bodies are a PIA.
While waiting on parts, I decided to tackle the solar wiring modifications I knew were needed. This coach had 3 x 100W panels and a BlueSky 3000i controller installed by AM Solar back in 2015. AM Solar having been one of the best, this is one part of my upgrade I expected little issue with. Sigh...the best laid plans.
AM Solar installed the BlueSky controller on the side of the cabinet above the sink, facing the doorway as you come in. A common place in the midbath no doubt, as the controller also has a display showing all aspects of the system.
However, in the Victron world all display and control is typically handled in a single place, regardless of component. In my case, that will be a Cerbo GX connected wirelessly to an Amazon Fire tablet, a setup I recently installed in an Airstream that works beautifully. I'll fab up a mounting panel and place it where the BlueSky was to cover the hole. Anyway, the main point being - a LOT of solar wire runs in the AM Solar installation needed changing/removing.
Many of you are aware, but regardless of solar controller - a typical wire run is from the panels to a combiner box, then to the controller, then to the batteries. With the BlueSky installation where it was, this resulted in the following:
- 6/2 wire run from rooftop Combiner Box going through the fridge roof vent, then through the upper cabinets and to the Bluesky
- Another 6/2 wire run going from the BlueSky back along the same path through the cabinets/fridge vent, then back down the side of the fridge to the battery box.
My plan was seemingly simple. Remove the wire runs going to the BlueSky and repurpose the 6/2 cable running down the side of the fridge to feed the new Victron solar controller that will reside down there. So, yank some cable, cut the one running down the fridge vent and splice it back into the combiner box...maybe 20 minutes? Ha.
Removing the two 6/2 cable feeds to/from the BlueSky was easy, but when it came to the cut/splice in the combiner box - it disintegrated. The combiner box used back in 2015 by AM Solar literally fell apart upon opening it up.
I knew from an installation I did about a year back that AM Solar was selling a really nice rooftop combiner box of their own design, but with them out of business - I went on the hunt to find a quality replacement. I suspected AM Solar only designed the combiner box they were selling, and sure enough - I tracked down the company making it. I stumbled upon the Deployed Logic (DLX) Combiner Box, and a quick call to their support confirmed it was the same box. The guy helping me actually worked at AM Solar.
With that ordered up, the wiring went off without a hitch. The box is super low profile, and in the likely event I add two more 100W panels - one will likely go right over the top of it. It installs with VHB tape, and I'll seal up the roof/box edges with a little Dicor.
2002 26.5 MB
Was it James, who now runs Kindly Solar?  We bought our combiner box and some AM Solar mounting brackets from him in 11/2024.
Sorry, don't recall the guy's name. I'm under the impression he's an employee of Deployed Logic as that's who I called.
2002 26.5 MB
Finished up the day with a pleasant surprise. I'd been looking into a hard-wired surge protector, and had pretty much decided to get the Progressive Industries EMS-HW30C. Turns out...the previous owner beat me to it! It's already there and already installed.
I've not traced all the wires yet, but I'm guessing it is wired in after the transfer switch to filter both shore power and generator. The Victron Multiplus needs to be added to the mix, and I'm double checking that now - but my guess is, it should go in after the EMS and before the AC circuits.
2002 26.5 MB
Hi Will. If you could share a picture of your surge protector install I would much appreciate it. I have the same unit and LD model and need to install it.
It's installed similarly to others I've seen posted here. Under the sink on the shared bathroom wall. Here's a view from behind the power center. Sorry for the blur.
Here are the connections to the power center. I'm assuming the input comes after the transfer switch, the output feeds the AC circuits - but I've yet to verify. The EMS cables are in the black sheathing. My plans are to splice the Multiplus AC lines into the output line of the EMS prior to it entering the power center.
As with other installations, the readout was attached to the wall above the power center - seen here.
2002 26.5 MB
Assume you mean taking the output of the EMS and running it through the Multiplus, utilizing the passthrough capability.
You don't want to splice the output of the EMS and the output of the Multiplus together and then feed the breaker panel.
I could have stated it more clearly, but I think we're on the same page?
How I think it currently goes:
Shore power/Generator --> Transfer switch --> EMS In --> EMS Out --> AC Panel in power center
How I think it should go with Multiplus:
...EMS Output --> Multiplus In --> Multiplus out --> AC Panel in power center
2002 26.5 MB
Reply #24
Yes  :)   When I read the original post with "splice", I thought you were considering wiring EMS output and Multiplus (as inverter power) output together (2 wires spliced to 1), and then running that to AC power in.
BTW, the most recent models of Progressive EMS (now owned by Navico) operate slightly differently than the original ones (as we discovered installing a new one in our coach.)  It's something buyers need to be aware of, so I'll start a separate topic on that.
