Topic: Starlink - More Questions (Read 379 times) previous topic - next topic
I am very happy with the Starlink Mini.  However, I have some questions:
1.  Someone suggested that I run the cord, which is thinner than the one on the Starlink Standard, through the passenger door where there is rubber weather stripping.  I don’t like the idea of having a window open for the cord.  Is that a good option?   Would it damage the cord or affect the Starlink’s performance?
2.  With the Lazy Daze’s curved ladder is there anyway of using a pole on the ladder for the Starlink Mini?
3.  I’ve heard that some people keep their Starlink inside their RVs and that they work.  I tried that but it didn’t work.  Has anyone placed the Starlink indoors and it worked?   If so, where did you place it?
Thank you in advance for any feedback.
Monica
Monica
2017 MB
Re: Starlink - More Questions
Running a cord through the door isn't my preference. Yes, I've tried it in the past with an outside cell antenna, whose cord is even thinner than the Starlink Mini's, but it's hard to keep it in position. And every time you close the door, you kink the cord again, risking eventual damage.
A recent post in the "Surviving Milton and Starlink" thread suggested running the Starlink Mini's cable out the window and then using a foam pool noodle to seal against weather. That's the quickest, easiest way.  If you slit one side of the noodle lengthwise, it should stay in place even with the window open. Another method is one I recently suggested: run the cable out through a hole in the outside shower compartment. That's more work, but more convenient in the long run.
\2.  With the Lazy Daze’s curved ladder is there anyway of using a pole on the ladder for the Starlink Mini?
A forum member recently reported hanging his Starlink Mini inside the shower skylight and having good service. It is the only place in your MB's roof where the Starlink reception isn't shielded by the sheet aluminum roof.
Google "Starlink Mini RV mount" and you will find all sorts of ladder and roof mounts.
Thank you, Larry.  I may try hanging the Starlink Mini by the shower skylight.  Will report results if I do.
Monica
Monica
2017 MB
Thank you, Andy.  I don't have an outside shower so that option won't work.
Monica
Monica
2017 MB
Hi Monica, I saw a suggestion on one of the Lazy Days Facebook pages about mounting a mini starlink in the shower.
 We tried it out. We placed the starlink mini inside of our indoor shower skylight. It has been working great for us.  It is removable so if we are parked under trees we can position it outside in an open area. It has to be right up in the skylight to work.
For outside use, we plug it into the outlet that is inside the refrigerator access door. We use a short extension cord in there because the power block on the starlink doesn't fit in with the fridge plug. No cord needs to run through a window.
I hope this helps.
Theresa & Everett  GLLDCC Making wonderful friends at LD rallies.
Surfside our 2018 31IB ( our current LD)   Sandcastle  2001 26.5MB ( our first LD)
Michigan born and home based. Traveling with our spoiled dog Dax.
"We placed the starlink mini inside of our indoor shower skylight. "
Thank you so much, Theresa and Everett.  This looks like a great way to keep the Starlink inside the RV.
Monica
Monica
2017 MB
