Topic: Dual Tire Pressures (Read 226 times) previous topic - next topic
Dual Tire Pressures
My understanding is that you want the dual tire pressures to be evenly matched. Checking my pressures this morning, I noticed that the inside tire on one side is 2 pounds lower than the outside tire. Is this a concern?
Re: Dual Tire Pressures
They should be the same but 2# is no big deal. Maybe the outer tire is heated by the sun. I'd just keep an eye on it to make sure it's not losing air.
jor
09 27' MB
10  Suby Forester
Thanks, Jor, the sun is not a factor as it’s not up yet!
I read somewhere about having the inner tire about 2psi lower than the outer to compensate for road camber that causes uneven wear between the tires.
