Topic: Solid (steel, not braided) long tire stem for inner dually replacement? (Read 199 times) previous topic - next topic
Happy New Year, everyone!
      I had four new rear tires installed this morning at Discount Tire.  When I got back to the house, I was putting the TPMS sensors back on and noticed that one of the inner dually stems was damaged at the tip of the thread and I couldn't screw on the sensor.  Hard to see & hadn't noticed it when I was at the shop.  I zoomed in with some pictures and there's definitely a gouge in the threads which must have happened when the tire was mounted/installed, I'm guessing.
    I called Discount Tire and they'll install a new stem no charge, but they only carry the flexible braided type.  I've read that the solid steel ones are better, but I'm not sure where to source a replacement or even exactly what I'm looking for.
   I've hunted around on Google & Amazon and there's all kinds of extended tire stems, but I don't see the same type that's on there now.   Any ideas or tips would be greatly appreciated!    If I can't find the solid replacement, I'll just go with a braided one at least temporarily.
   Thanks!
 Daryl
    Just searched again, found this:Dually Valve Stem Kit for Class C Ford E350, E450 with Steel Wheels 2″ Hand Hole – DL1EC (manufactured by Borg)
  Always Shiny Wheels and RV | Dually Valve Stem Kit for Class C Ford E350,...
  "Fits These Wheels:
Alcoa Wheels - 160281
Alcoa Wheels - 160282"
Is this what I need?
Daryl
2021 Jeep Wrangler Sport S
SKP #145689
Re: Solid (steel, not braided) long tire stem for inner dually replacement?
Go to AutoZone and pick up a vave stem tool. It has a thread chaser on one of the legs. It wil fix you right up.
Just looked at the picture. That solution won’t work.
Harry 2006RB
Hi Daryl. That tire looks pretty damaged!  Were these solid stems mounted on that wheel?  The tire techs should have found that before placing it on the steel wheel. The Borg stems you provided the link for are for the aluminum after market wheels. You don't have those.  Before 2008 the steel wheels had eight round holes.
   2008 and newer had oval hand holes (4 of them) on the steel wheel. Us with older rigs have 8 smaller round holes..
    This is the source I have on record (archives).  DL1EC Chrome Duallyvalve Kit  They reference older wheels 1992 through 2007.  RonB
Hi Ron,
      Thanks, yep that looks like the one!   I couldn't remember "Borg" which is the parent company of your link to Your Tire Shop Supply website.   It doesn't look like I can just order the long stems, only the complete kit, so I'll have spares.
Will get that ordered & Discount Tire will install it and hopefully be good to go :-)
   Yes, the long stem was mounted on that wheel that had the tire blowout.
 Daryl
Daryl
SKP #145689
Give Borg a call and order the long stem shown in the kit. Discount Tire broke one of our stems and Borg provided the replacement.
I ordered two stems to have a spare. It is easy to bend or break the long stems when the tires are replaced or rotated.
thanks Larry!
    Just got off the phone a while ago with Borg, super helpful.   Said their warehouse was closed for inventory for a couple days, but he had one replacement stem in stock & is shipping out today :-)
daryl
Daryl
SKP #145689
