Topic: Starting generator (Read 178 times) previous topic - next topic
Starting generator
Will the Onan 4000 generator start using the engine battery only or will it need to be connected a 30 amp outlet or use the house batteries. I pulled my house batteries for the Winter.
Thanks
2002 30' IB
Re: Starting generator
Will the Onan 4000 generator start using the engine battery only or will it need to be connected a 30 amp outlet or use the hose batteries? I pulled my house batteries for the Winter.
The generator needs the coach battery installed to start. The converter is not powerful enough and the battery isolator will not pass enough amperage to start the generator. I would not try to start it without the battery, this may destroy the isolator.
Thanks Larry. That's what I thought.
2002 30' IB
Hi Larry-
Are you knowledgeable about factory installed solar?
Thanks!
2002 30' IB
