Topic: Happy Kitchen (Read 674 times) previous topic - next topic
Happy Kitchen
We installed a new Moen faucet with 2 shut off valves.  The Chef is pleased.  Tomorrow’s job is replacing the broken vent cover in the bathroom.  December’s job is to add an electric socket on the front end of the cabinet over the dinette table.
Then we’re done for awhile with these kinds of projects.  On the other hand, we have a moderately fogged window in the lounge on the driver’s side.  That’s an expensive job ($750) that can be done locally.  We’re not in a hurry to do this job.  Time and wallet will tell.
Re: Happy Kitchen
Lookin' good, Ed. Shutoffs are a great idea.
jor
09 27' MB
10  Suby Forester
Re: Happy Kitchen
Could you please post a link to the faucet? I see several similar ones when I do a search online. Thank you!
Jan Forseth
2007 27' Midbath named Footloose
Re: Happy Kitchen
"We installed a new Moen faucet with 2 shut off valves.
Nice, Ed! Could you provide more info on the second shut off valve?
Re: Happy Kitchen
I’m not understanding this question.   The second shut off valve?   There’s a hot and cold water valve.  I’d be more than happy to provide more information.
Re: Happy Kitchen
Hi Margee;  I think Greg was asking about a shut-off valve placed in-line before the water lines get to your new fixture valves.  Since the new valves, part of your new fixture are above the water tank, and the pump shut off switch is handy, you really don't need more plumbing to potentially leak.
   Your new faucet looks very nice. The single handle is good for me, but just last campout I left a dribble going after I refilled the cat water drinking bowl during the night.  (couldn't hear the pump cycling).  So the gray water tank wouldn't have overflowed for a while, and I did have water available nearby.... could have been a poor situation.  RonB
Re: Happy Kitchen
Jor installed Sharkbite PEX valves when installing his new sink. It's a smart idea, so I bought a pair of valves to use if a faucet or other water accessory springs a leak.
Cutting and inserting a PEX valve isn't hard.
Installing shut-off valves on the sink is a great idea when installing new faucets or at any time. Be aware that Sharkbite valves are a pricey way to go. Without shut-off valves, any leak requires shutting off the entire water system,
I also carry 1/2" PVC plugs to shut off individual faucets, the plugs screw into the faucet's supply lines.
Emergency faucet caps | Cut offs from an old faucet to be us… | Flickr
Re: Happy Kitchen
Thank you Ron for clarifying Greg’s question.  We installed SharkBite valves in the lines going to the faucet.   I’d like to do the same thing on the other water lines as a safety feature which will allow us to cut off a problem area without shutting off water to the entire house.   That’s the theory anyway.
Re: Happy Kitchen
While adding shutoff valves (SharkBite) makes logical sense, aren’t you increasing the chances of a leak by introducing new points of failure?  Or are the SharkBite valves that good?
Dave
2017 TK
Re: Happy Kitchen
Sharkbite fittings are certified for new construction. They are the ticket for remodels and plumbing repairs in tight places.
I carry a pair of fittings for emergency use, They may never be used.
Re: Happy Kitchen
Anyone have a link for the Sharkbite valves - would like to take a look at one.
Re: Happy Kitchen
A few plumber friends mentioned that SharkBite valves have a higher risk of failure compared to other methods for creating 90-degree angles and other PEX fittings. They explained that this is due to the potential failure of the o-rings.
Sam
Re: Happy Kitchen
Part 2:
We used a small amount of liquid Turtle Polishing Compound and a 6” orbital buffer on the kitchen sink and countertop.  We did the same thing in the bathroom.  We think it’s much better.   And now we’re done.
Footnote:  We placed a tiny rubber band below the swivel spout and base (like an o-ring) which disappeared between the two pieces.  Now the spout moves much less which is what we wanted when traveling.
Re: Happy Kitchen
I have used many Sharkbite fittings through the years and have never seen a failure in RV and residential use. RV water pressures are typically about half of residential water pressure.
When using PEX, the cut must be straight, and the end deburred. Sharkbite sells a tool to deburr the tubing and to mark the correct insertion depth. PEX pipe with burrs can cut the o-ring and cause leaks. Proper preparation is critical for trouble-free use.
https://www.homedepot.com/p/SharkBite-Safe-Seal-Depth-and-Pipe-Deburring-Tool-U702A/100638148?MERCH=REC-_-fbt_test-_-100638148-_-0-_-n/a-_-n/a-_-n/a-_-n/a-_-n/a#overlay
Re: Happy Kitchen
In my case, the lines going to the faucet are braided stainless steel.  Not being familiar with the product, where would one install the Sharkbite valves?
