Topic: 2004 right side coach door lock springs (Read 299 times) previous topic - next topic
our lock handle on the inside is just sloppy as the springs inside the locking mechanism have broken so   trying to find replacement springs
A 2005 MidBath
Re: 2004 right side coach door lock springs
The lock can be disassembled and the two weak or broken springs that provide tension on the latch replaced.
I have found suitable springs at well-stocked Ace or True Value Hardware stores.
Even I managed to do it a couple years ago!
No problem.
Kristin
1997 MB
No problem.
While the lock is disassembled, it is a good time to clean the old grease insides and lube it with fresh grease.
https://www.amazon.com/Permatex-80345-White-Lithium-Grease/dp/B000HBNV58?th=1
