Topic: Overloaded (Read 583 times) previous topic - next topic
Overloaded
Not a motorhome but a good reminder to pay attention to weight specs, and to verify actual weights of our LD’s at a scale (ideally one that can weigh each corner).
https://www.rvtravel.com/broken-frame-lesson-stuff-dont-salesperson-1087b/
Re: Overloaded
How many times have I heard, “The man said it would be OK”?
The majority of auto salespeople have only one goal in life: to sell as many cars or trucks as possible, they do not care about how appropriate a vehicle is for a buyer’s actual needs.  The bottom line is to do your homework before buying.
Re: Overloaded
Some lessons are best learned second- or third-hand
dog Zeke
Re: Overloaded
Weighed ours this weekend. 1992 26.5 midbath. Full fuel, water and propane. Along with all our normal gear for a long weekend.
Steering axle 3860 lb
Drive axle 8020 lb
Total 11880 lb
Only item not with us was the ebikes and carrier which would add 200 pounds.
1992 Mid Bath
Re: Overloaded
Drive axle 8020 lb
Total 11880 lb
You are close to 400 lbs over the GVW without the bikes, does this weight include passengers?
Older MBs were built on the lightweight E350 chassis, with only 11,500 lbs GVW
A big problem with MBs on the E350 chassis is the small brakes. Be careful on downgrades, it would be easy to have the brakes fade if not using the gears to keep the speed down.
Re: Overloaded
I have to emphasize that Larry is serious.  The two times I measured my '99 E350 I was about 25 pounds over the 11,500# limit.  I travel with less than full water tank now, about 35 gallons of water (instead of 54), and removed some 'lead acid' weight recently.  I also lightened some storage spaces.  Unfortunately those weights didn't include me, but I lost some pounds too.  I do have the same tires as the 14,050 26.5 and 27' rigs.
   I have smoked the brakes coming down from Big Bear, the weather was hot!  (No vac assist, those squirrels!). Pulled over to let them cool off.   RonB
Re: Overloaded
I would never, never, never, take the word of a salesperson for much of anything, particularly something so important.
Before we bought our 2004 Lazy Daze way back when, we were shopping for Class C's. Came across one that had a "garage" in the back where you could load an ATV into it. Looking at the CCC, I saw that it was something like 600 lb. Made the comment to my husband that once someone loaded an ATV into the garage, that would take up the majority of the CCC, if not all of it. The salesperson overheard me and tried to convince me that the weight of the ATV would come out of the towing capacity, not the CCC...she said the factory representative had told her that. I knew she was wrong and tried to convince her that the weight of anything loaded into the back would be subtracted from the CCC, but she was having none of it. I often wondered if some unsuspecting person bought that RV and ended up vastly overloading it.
Linda Hylton
Re: Overloaded
Yes that included both of us and dog. Down hill always let engine and trans do the work. Normally when we travel only have about 10 gallons of water in tank. I did the same weight with our toybox 30ft. Wanted to see what it was fully loaded with jet skis.
Hope others learn and weigh their rigs. People will be amazed at how much stuff we cram into traveling
1992 Mid Bath
