Topic: Electric Step Motor (Read 220 times) previous topic - next topic
Electric Step Motor
Now that we finally have cooler weather, we decided to change the motor on the electric step.  Our step failed in the closed position which on our step makes it impossible to reach the cotter pin and retaining pin to release the step.
By shear luck, the step opened after several attempts which happily shocked the … out of me.  The replacement is as easy as so many here have mentioned.  However, I learned the hard way that the retaining pin and cotter pin must be installed before installing the new motor.
I’m not telling how long it took me or how dirty me and my tools got but let’s just say this so called simple project is done. 😂
I don’t know how someone could do this repair if the step remained in the closed position.
Hope this is helpful.
Re: Electric Step Motor
Mine is working well but would like to know if you have a link to buy the replacement.
Joe B.
This is the one I ordered from Amazon.
676061 RV Stair Entry Step Motor Replacement for Kwikee Step Motor Part Number 1101428 379147 214-1001
It was a perfect fit.  Hope this helps.
   edit by RonB to include the link:  https://www.amazon.com/Replacement-Compatible-Lippert-Components-214-1001/dp/B09MKPKR7R
I might suggest the following sequence.  When the step is in the open position, first disconnect the power to the motor.
Then remove the cotter pin and retaining pin which takes the pressure off the internal gears of the motor.  It’s then easier to remove the motor which is secured with 3 10mm bolts.  It’s necessary to jiggle the motor to get it disengaged from the internal gears.
Now reinstall the retaining pin and cotter pin.  Finally install the motor and jiggle it so that the internal gears mesh.  The new motor uses the drive gear, a pin, and 2 washers from the old motor, which we cleaned and greased.  I also greased the gear above the motor which controls the step.  And finally replace the power cable.
Lastly, lubricate all the fittings on the step, check the 4 bolts holding the step, and clean the light cover.  Done!
At least, that’s how we did it.
