Fender Flap Trim September 22, 2024, 02:57:44 pm I'd like to replace the vinyl trim on the rear fender flaps as mine are looking kind of grubby. Anyone have a source for the same size (haven't talked to Todd yet)? I added some to the inside of the flap to protect my back while working in there when the flap is not held up with a rod or whatever. I ordered what I thought was the right size (Amazon photo) but it was difficult to get on, not as wide as the OEM and as you can see in the photo, I could not get it to lay flat across the entire run. Fine for my purpose as it is out of sight but won't do for the visible flap edges. Thanks.jor 1 Likes
Re: Fender Flap Trim Reply #1 – September 23, 2024, 05:20:32 am Hi JOR; Looks pretty much OK to me. I'd try a rubber mallet to seat it better on the edge. Would reduce that waviness. To hold that flap (partial tire cover) up I built in aluminum props. Useful also if I ever needed the snow cables on the tires. The prop can be installed horizontally to keep the cover about 4" out (with bungee cord). Away from the tire vicinity. RonB 2 Likes
Re: Fender Flap Trim Reply #2 – September 23, 2024, 09:31:21 am Ingenious flap holder you got there, Ron. Re the trim, I probably confused my question with the wavy comment. That is the trim I put on to keep the inside edge from rubbing on my back if I don't block up the flap. I'm asking about the outside trim. I'll contact Todd and see what he's got on hand. Thanks.jor
Re: Fender Flap Trim Reply #3 – October 02, 2024, 05:47:11 pm Ended up just cleaning up the vinyl flap trim. I think most of the discoloration came from the Rejex that I use to polish the paint. Anyhow, I cleaned them with Dove and applied Aerospace 303 which I use for any rubber or vinyl (e.g. window gaskets). We'll see how long it lasts. I usually do the windows every two or three months. Todd told me he doesn't have any of the stuff but the source is Trim-Lok. (trim-lok)jor
Re: Fender Flap Trim Reply #4 – October 02, 2024, 08:10:21 pm Trim-Lok also makes the trim used around the faux spare tire cover.Amazon.com: Trim-Lok Trim Seal with Top Bulb â Fits 1/8â Edge, 3/8â Bulb... As an Amazon Associate Lazy Daze Owners' Group earns from qualifying purchases.
