Topic: front shock replacement on 1997 26.5 (Read 315 times) previous topic - next topic
Has anyone here done this ?
1997 Rear Bath
Re: front shock replacement on 1997 26.5
Yes. Want do you want know?
On a 1999 I did, about a year and a half ago I did front and rear.
I found my newly bought small cordless reciprocating saw came to the rescue cutting the top bolt.
Steve and Jill, Steve posting
1999 26.5 Mid-Bath
Sure do...
1997 Rear Bath
Recommend a search.  Koni and Bilstein are common replacement brands, and will make good search terms.
For example: Advice on Shocks
On a 1997, you're probably due for sway bar bushings and a steering stabilizer unless they have been previously replaced.
Thanks ....RV shop wants 200 bucks an hour ?!?..... I think he also gives legal advice.....for that fee...yikes..
1997 Rear Bath
Real talk - owning an old RV (ok, any RV) is expensive.  Most people DIY as much as they can and it still costs a lot.   $150-200 isn't a crazy shop rate these days depending on the market.   If you're not comfortable DIYing things, you will soon be spending more than is reasonable given the value of the vehicle.
One trick RVers sometimes use is to get service done while traveling in places with lower rates.  It can reduce the sting, but it still costs $$$
The driver side top shock nut is difficult to get to.
A multi-head wrench makes the job much easier.
ARTESIA TOOL 10" (25.4 cm) 16-IN-1 Multi Head Wrench | Chrome Steel Construct...
