Topic: Gray & Black tank cleaning (Read 1171 times) previous topic - next topic
I remember seeing posted here a while ago about cleaning black and gray tanks with enzymes. We are getting back to the hot weather now which was suggested to be the best time enzyme treatments to clean tanks. What's recommended as a good cleaning enzyme for black and gray tanks.  In the past in the PNW we never had this opportunity but now while we're here in Reno, it's hot so I think it's time!
   Karen~Liam
      98 ~MB
        NinA
1998 ~ MB  WanderDaze
Re: Gray & Black tank cleaning
This doesn't really address your question but imo there is no need to ever clean the black or gray tanks. In our case, when we dump the black, we flush down a pail of water and after dumping. Then we add another pail of water along with some Dawn and Calgon. The tank remains clean. A few years ago I was able to verify this when I had to remove our black tank because of a leak. I examined the inside and it was clean as a whistle.
Regarding odor, if the air admittance valves are functioning and the P-traps are full, there should not be any odor emanating from either tank.
The smaller tank on the right was our black tank. That's the one I examined.
jor
09 27' MB
10  Suby Forester
There’s few if any RV topics that have so many diverse recommendations.  The retail solutions make lots of money with the promise of tanks so clean that they smell like roses.  Similarly home brew solutions are touted as less expensive and better than anything you can buy.  Plus these solutions smell like daisies 😂.
I haste to offer any recommendations because…well it’s a question without a preferred solution.  And that’s my .02!
"...there is no need to ever clean the black or gray tanks."
Can't say that I agree with that!
Regardless of whether you have INTERIOR or EXTERNAL (like SeeLevel) tank sensors, the effluent in the tank will build up a ring of debris at the typical 'high water' mark. This ring of crud can play havoc with the monitor, leading to false readings. Been there, done that!
And that is why we have been using an enzyme product called Eco Save at every dump. Those hungry little critters will eat that crud and help assure reliable level readings.
Eco-Save Bacteria/Enzyme Products are manufactured by JWH Distributing in...
Our LD holding tanks get flushed well every summmer and then each tank gets a good dose of septic enzymes and fully filled with fresh water . It sits for a week  or more in the summer heat.
It is amazing how much crud comes out of a ‘clean’ tank
when drained.
Well, guys. All I gotta say is my empty black tank which I used the same method on for a number of years didn't have any ring or any crud inside and I never have had any SeeLevel tank reading issues. That Dawn-Calgon deal used to be called the Geo method and it has served me well. However, Ed is right. This topic always stirs up the .... As on old poster from the past used to end every post, Do what makes you happy!
jor
09 27' MB
10  Suby Forester
Well, guys. Thistopic always stirs up the .... As on old poster from the past used to end every post, Do what makes you happy!
Goes to show that there is more than one way to clean the tanks.
Larry what enzymes do you use?
   Karen~Liam
      98 ~MB
         NinA
We will be leaving our 98~MB in Reno for the next few weeks so we could fill it with the enzymes and let it cook!
Can't do that up in the PNW!
   Karen~Liam
     98 ~ MB
        NinA
Hey yall
Can someone tell me the recipe for the calgon/dawn black tank cleaner.
I have heard that it works very well and I'd like to try it.
Really appreciate this forum!
Thanks,
Cal
2002 MidBath
Hey yall
A company called Kleen Tank does RV black and gray tank cleaning, and has distributors in various locations.  EnjoyTheJourney.Life YouTube channel has a video on RV Products That Damage Your RV! Black & Grey Tank Cleaning Myths
They recommend NOT using enzyme additives that break down the contents.  The representative says that it does break down the waste, but makes a "sludge" that turns your holding tank into a septic tank.   They have a recipe for tank cleaner, but it uses Calgon bath pearls and PineSol cleaner.  Here's the suggested tank cleaning recipe
Kleen Tank has dealers where you can have your tanks cleaned (I think it's $275), or are present at various RV rallies (usually $250).
I've actually switched from using Happy Camper to this recipe.
Cheryl (a.k.a. Desert Diva)
2002 Honda CR-V
We don't even measure anymore but probably a cup of Calgon and a big squirt of Dawn followed by a half bucket of water. This method will not clean a tank with built up residue but if you do this at every dump your tank will remain clean. And as I said in another post, if your plumbing is in order (functioning air admittance valves and full P-traps) you will never experience the stinky coach syndrome! In my opinion, the thing to remember is these waste tanks are not septic tanks, they are just temporary holding tanks. Good luck.
jor
* Forgot to add, after the black is empty, we flush down a pail of water and then close the valve (this rig has separate valves for black and gray.
09 27' MB
10  Suby Forester
As an owner of 2014 TK we have never 'cleaned' either the gray or black tank.  What we do is every three or four 'dumpings' we do a visual clean.   The person with the water (clean out) hose cleans with a strong flow of water moving the hose all around and up and down.   The person on the dump station side watches the clear elbow.   When the water flow is clear all is good.
This method has worked very well over the years.
glen
Thank you for sharing your knowledge. Could you post a link to the exact type of calgon you use? I appreciate any help you can provide.
Sam
Kleen Tank (formerly known as All Pro Water Flow) tank solution that treats your black and gray RV tanks.
To make a batch of the Calgon PineSol Solution, mix up a gallon of this solution to use in both the black and gray tanks. It will keep the internal surfaces of your RV’s holding tanks slippery (reduces build-up), sanitizes the tanks, and has a nice, fresh smell.
1. Start with an empty gallon jug
2. Pour 1/4 cup (4 ounces) of Calgon Bath Beads (or liquid) into the gallon jug
3. Fill the jug 1/2 full with water. Shake well.
4. Slowly pour 40 ounces of PineSol into the jug. Shake well.
5. Top off the gallon jug with water. Shake well.
Use 8 ounces (one cup) in your black tank(s) and 4 ounces (1/2 cup) in your gray tank(s) each time, after emptying and back-flushing.
Note:  Many experts advise AGAINST using Dawn dish detergent as the build up of the bubbles can create a film over the sensors.
Calgon and PineSol are readily available at your local Wal*Mart...
2002 Honda CR-V
Same stuff as Cheryl just posted. Never had any bubble trouble!!!  :D  :D
jor
09 27' MB
10  Suby Forester
Aww, I came back to this group out of nostalgia, having sold my LD many years ago, and it's hilarious to see this topic persist!  I used a cupful of Calgon water softener and dish detergent. It's not available in areas with naturally soft water, such as most of the Northeast, but it's right there on supermarket shelves in other places. Or, of course, through Amazon.
Yea, Joanne, it always generates a lot of passion, right up there with tire pressures!!!  :D
jor
09 27' MB
10  Suby Forester
when drained.
I just tried this (using Bio-Clean) and it worked great.  My black tank sensor is no longer stuck on 2/3.
2003 MidBath
The inside of the holding tanks can develop coatings that interfere with the sensor probes. Enzyme and/or bacteria treatments digest the coasting and turn them into a liquid, doing the same jobs as bacteria in a septic system tank.
It takes time to digest a well-coated tank, best to do it in the summer, when it is hot, speeding up the microbe’s work.
Another method of cleaning the tanks is to drive a good distance with a partially filled tank, adding several ounces of dish or washing machine detergent to each tank.
Installing holding tank flushers is a good idea.
Camco Tornado Rotary Tank Rinser
https://www.amazon.com/Camco-40126-Tornado-Rotary-Rinser/dp/B000BUU5TU/ref=sr_1_5?crid=1ZQWNYLIU9YG6&dib=eyJ2IjoiMSJ9._vbIS6Ik9TLIM7IGHyQSRf7gZzEn-6a2mx01C-omhj1BauC5XQt9i6l0hOOXyH9XPmpYGWBAkUCNif7L4lxyav53sOUoASwnVwSTQ1vocdrSKbaXi-iRpuWgcraOd57JvlqgiGvG9xZlOXRBk0HoSQOqdFo6kBtT0L1yiix3gytxE97Js2MwAESByJCLVTF9TVP77AlCc5nPtD9N-KXYO-1oY4ATPDO8kpAe2-RYfq_nIUoe59U4UyUwiGYeUM04I62l18SOpdpbof2DPdm7BSbDuzdQ3g7nIvg2nnksFE8.TfLBvXhK6B3DwPw6n9K11pff5McUE6MLvy3D8moF1sQ&dib_tag=se&keywords=camco+tornado+rv+black+tank+flush&qid=1723075815&sprefix=camco+black+in-tank+flush%2Caps%2C164&sr=8-5
Larry,
Where does the other side of that valve go?
Will, with a 1999 MB, 7.3L PowerStroke
The quick-disconnect inlet is where the hose, with a matching quick-disconnect fitting, is connected.
The two-way valve directs water to either the black or gray tank's flusher..
https://www.homedepot.com/p/Orbit-Heavy-Duty-Metal-Quick-Connect-Set-with-Automatic-Shut-Off-Hose-Fitting-Connector-27942/100659315
We have a Valterra 45 Degree Hydroflush for a long time now and have used it whenever possible.  We are now planning on getting a Valterra T58 Twist-On Waste Valve to add to our dumping procedure so we can fill flush when we flush, if a water hose port is available.  There is also a combination unit called the Valterra Flush King 45 Degree Reverse Flush Valve but we already have the flush unit.  We used to fill the black tank for flushing with toilet water but that was a long procedure.  We are hoping that with this flush setup it will go a lot faster and now everything will happen outside by the valves.
       Karen~Liam
         98 ~ MB
            NinA
T-58
Amazon.com: Valterra T58 Twist-On Waste Valve, Mess-Free Waste Valve for...
Hydro Flush
Amazon.com: Valterra 45 Degree Hydroflush Attachment with Removable Anti-Siph...
Flush King
Amazon.com: Valterra Flush Kingâ„¢ 45 Degree Reverse Flush Valve Attachment...
A Hydroflush is a must-have accessory for a Mid-Bath. The black tank suffers from waste build-up near the dump valve sometimes to the point where the black tank drains slowly or not at all.
A Hyroflush does a good job of cleaning the tank and of keeping its full capacity, it works well on any dump valve with a straight shot into the tank. It does not work well on gray tanks with long pipe runs between the tank and dump valve. An in-tank flusher works best in this situation.
