Topic: Cab A/C stuck on defrost  (Read 393 times) previous topic - next topic
When I turn on the A/C in the cab it will only blow air from the front window area. Anybody had this problem?
Re: Cab A/C stuck on defrost
When this happened in our Lazy Daze, the culprit was the vacuum line from the manfold to the vacuum accumulator.  Rodent damage.  When I replaced the vacuum line, the dash vents were restored.
Harold
2014 27 MB
Happy wife=Happy life
Hi Dale,
Many posts about this, below is a link to a recent discussion. My reply #1 has a link for an earlier thread about this, and reply #7 describes what I purchased to do the repair.
I referenced the Companion article on this topic (not sure if that is available again) and the youtube video I used for some guidance on how to install the check valve and where to place the reservoir.
Cabin A/C, no air coming out of vents
I hope this helps. I was a relatively easy job for me (and I'm not a skilled mechanic-- unlike quite a few on here).
Jason
Jason
2003 Rear Bath
"Razor Crest"
Dale,
Here's another good video on the fix.
jor
a/c vacuum
09 27' MB
10  Suby Forester
Harold
Exact same thing happened to us - wasn't a fun nor cheap repair.  Seems those vacuum lines are a delicacy amongst the rodent class...
Zia, our 2013 27’ RK
2006 24' TK, sold
SKP Lifetime member #105622
Land of Enchantment
Thanks for all the help. I’m pretty sure I’ve got a grasp of what the problem is and how to remedy it. It looks as though the bypass valve and the vacuum canister are the culprits. Since the vacuum canister is buried deep in the engine it is necessary to abandon the old canister and add a new canister in a more accessible location. There are several very good videos on U-Tube that show exactly how to do this. Thanks again and be well, all.
I did this repair on my rig today.   It was a 30 minute fix once I understood the issue and located all of the parts.
This video was helpful to me (same one linked a couple of replies up).
https://www.youtube.com/watch?v=-192lHUs8nY
Troubleshooting the issue consisted of checking for vacuum (with the engine running) in the engine compartment (behind the oil fill neck) and on top of the dash under the pop-off cover Ford provides to access the blend door actuators.
Parts included:
A/C Vacuum Reservoir Tank & Bracket for Ford Econoline Van #YC2Z-19A566-AA
Motorcraft YG193 Vacuum Checking Switch
A very short length of 1/8" vacuum hose
I was able to re-use vacuum fittings from the existing setup and didn't need any extra.
