Topic: P0351, likely bad coil (Read 250 times) previous topic - next topic
2017 E450 running rough, with code
P0351 "Ignition Coil "''A"'' Primary Control Circuit/Open"
Indicating a bad ignition coil.
Problem is I’m a good 100 miles from reasonable repair choices.   How bad is to drive a couple hours missing one cylinder?
Also, any mechanic recommendations for Pittsburgh?
Thanks
Dave
Dave
2017 TK
Re: P0351, likely bad coil
How good are you as a mechanic? Any Auto Zone or O’Reilly’s will have a coil. Lots of You tube will explain the major but doable job of replacing it.
Harry 2006RB
Not good at all as a mechanic.
I might have a spare, but coil 1 is a pain to get to, I can barely reach it from the front.
Dave
2017 TK
Once the engine cooled off, it’s not misfiring.
Temped to inch closer to Pittsburgh rather than hope to find anyone reliable two hours south.
Dave
2017 TK
I just had coil 8 and all spark plugs replaced. No, I did not do it. $1500. I might try the next one. Coil 1 should be the easiest but still not trivial.
I drove 50 miles home with no complications.
Harry 2006RB
Hi Dave;  I'm hoping that would explain those misfire codes that no one could locate.  Don't drive on the missing spark on that cylinder. Larry Wade had a sparkplug blow out, plugged the hole up and forgot to disconnect the fuel injector. That would be similar to driving with no coil.  The injector kept going and washed the oil off the cylinder wall. That scuffed the cylinder bad enough to scrap the engine! (that would be up in the $6k+ range!)  If you needed to you could unplug the injector. With no gas and no spark, at least you don't have a hole there. You might be able to safely drive quite a way without damaging the engine.
    With 9 good cylinders and a lighter weight coach, no towed, you might not notice any difference.   RonB
Update:
We drove ALOT of steep grades up and down in West Virginia today.
The engine sat a good 60-90 minutes while googling and updating here.
Then decided to limp four miles to a Walmart and call it a night.  Or so I thought.
The misfire was gone and AC was working once again.  Decided to push on another 35 miles to tonight’s campground, turning around or boondocking somewhere if the misfire/running rough returned.   It didn’t, but the AC did run warm for a bit up a steep hill, but the misfire didn’t return.
Research found when you get a P0351 it can disable the a/c due to the misfire, which jives because the AC stopped working when the engine was running rough.
So the plan is to baby the engine, keeping a keen ear out for misfires (running rough/loss of power) to get to Pittsburgh, about a hour) to find a mechanic
Also thinking the high revs of up and down hills stressed (overheated) the coil?
Dave
2017 TK
Good idea, will keep that in mind.
Now I just need to find instructions for that.
Dave
2017 TK
I’d like to think so, but not really.
5k miles into the issue, all the coils and plugs were replaced in Anchorage, didn’t resolve the issue, cylinders 2 4 6 7 9 still reported misfires without running rough or loss of power.  All the wire harnesses are well connected.
Though this P0351 is something new, maybe I’ll get lucky this time, though I’m not holding my breath, I’ve had really good mechanics tear out their hair.
Dave
2017 TK
Not sure how far you personally want to get into the diagnosis, but I think this might help.
Yep, that was the first thing that popped up when I looked into P0351.  Were the coil access that easy, I’d be tempted to try, but give my skill set, I feel I’d do more harm than good, too much in the middle of nowhere to attempt.
Thanks!
Dave
2017 TK
Hi Dave, on your old problem of random cylinder misfires one poster thought it might be fuel filter related.
The folks in Albuquerque tested the fuel pressure and volume, both were just fine, didn’t explain the misfires.
Dave
2017 TK
