Source for replacement double 12 volt rocker switch April 28, 2024, 03:57:09 pm We own a 2015 27ft midbath. The rocker switch in the entertainment center that energizes the TV circuit and the antenna amplifier has failed. Does anyone know a source for an identical replacement double rocker switch? I've located similar double rocker switches but have not been able to find a source for an identical replacement. ThanksGeoff and Carol
Re: Source for replacement double 12 volt rocker switch Reply #1 – April 28, 2024, 04:07:54 pm This might fit into the current face plate.Amazon.com: RV Designer S261, Rocker Switch, 10 Amp, On / Off, SPST, Black,... As an Amazon Associate Lazy Daze Owners' Group earns from qualifying purchases.
Re: Source for replacement double 12 volt rocker switch Reply #2 – April 28, 2024, 05:03:19 pm Does it look like this one, Geoff?jor
Re: Source for replacement double 12 volt rocker switch Reply #3 – April 28, 2024, 06:54:58 pm Hi Geoff; As Harry pointed out you could replace just the switch part. Or the entire switch. I found this JR products in white: Amazon.com: JR Products 13585 Modular On/Off Switch - Double,White : Automotive but don't see it in black. I don't have this type of switches. RonB As an Amazon Associate Lazy Daze Owners' Group earns from qualifying purchases.
Re: Source for replacement double 12 volt rocker switch Reply #4 – April 28, 2024, 10:17:13 pm It looks exactly like the one in JOR's photo and the one RONB found on Amazon; the JR Products 13585 Modular On/Off Switch.Thanks, now I just need to find it in black.Geoff
Re: Source for replacement double 12 volt rocker switch Reply #5 – April 28, 2024, 10:54:27 pm QuoteI just need to find it in black.Geoff, You can have this one if you like. Just PM me your address and I'll send it over.jor
Re: Source for replacement double 12 volt rocker switch Reply #6 – April 29, 2024, 03:25:41 pm Thanks everyone. I've decided to just replace the one switch has Harry suggested.Geoff
