Topic: Factory oven conversion  (Read 592 times) previous topic - next topic
Greetings,
I'm considering converting my factory oven space for storage and/or possibly making space for a compact toaster/convection oven. Rack and shelf removal is straightforward but I am wondering how involved removing the gas heating element is and if there are any step by step instructions(accompanying pictures would be great:) out there. Thanks in advance.
Matt
2004 26.5 Island Bed. Gumby
2006 Jeep Wrangler Rubicon
Re: Factory oven conversion
Once the gas line is disconnected and a few screws removed, the oven can be lifted out, leaving a big space. The gas line can be capped off with a brass plug available at any hardware store in the plumbing section.
If converted to a toaster oven, it will require hookups to use, I guess dry camping is not your normal way of camping, and having a burner(s) is not needed.
I suggest not making modifications that are permanent and can be converted back to stock if a future sale is contemplated. It would be hard to sell if missing the stove.
Hi Larry,
I may not have been precise enough with my intial inquiry. What I was hoping to do is retain the existing appliance so I can continue to use the stovetop burners and just open up the existing oven space inside the oven door by removing the shelf and heating element inside the oven. Can I just remove the oven gas element in some way and still use the burners? If no, then I will just continue to use the existing oven space for storage. I dry camp frequently and do not want to lose my stovetop burners:) I do have power within reasonable proximity.
Matt
I assume that the toaster oven will fit inside the existing oven space, once the interior parts, including the burner assy is removed. The oven=n gas valve will need to be capped off on top for safety.
Here is a photo of the entire gas system showing the manifold, burner, and stove gas controls, along with the tubing leading down to the oven burner. it appears the oven's gas valve fittings unscrew. you will need to find the correct plugs
Atwood / Wedgewood SVC Gas Assembly 54130 | pdxrvwholesale
Toaster ovens vent their excess heat somewhere, usually at the back or on the top. Make sure it can breathe and not overheat. The oven has a small vent at its rear that may be useful.
Thanks so much for the additional information Larry. That picture is really helpful too. I think I might go ahead and explore this project further based on your input.
Matt
Matt, if you want to retain the three-burner setup, you can gain the most space by taking out the entire stovetop/oven unit and putting in a "just plain" cooktop. If you match the existing stove's brand, you can probably get one with the same dimensions. The gas line that went to your current stove will connect to a stovetop, no problem. This will open up a lot more storage space than if you just use the inside cavity of the existing oven.
I think the interior of the current oven - if inefficient space-wise - still will handle the heat of a toaster oven more safely than a converted storage area. An option would be to just store the toaster oven below then use it on top of the stove cover.
"An option would be to just store the toaster oven below then use it on top..."
Whoopsie doodle! Those things aren't lightweights! If I had to lift mine that distance every time I wanted to use it my back would give out quickly!   :-\
The clearances needed for the toaster oven are also necessary to avoid damage to its components (any plastics and especially controls/electronics).  Operating it in a confined space will trap the heat in and likely shorten its life considerably.
I just removed my oven.  Put in a sliding shelf that stores the Treager and extended the tabletop over the top.  Working on a quick front door to cover the opening.
1997 TK
Nice, post photos when you’re done.
Dave
2017 TK
Not done yet but this is the temporary solution, here is the album (Sorry, but you are not allowed to access the gallery)
Temporary fiberglass epoxy top and a quick pocket hidge door.
1997 TK
