Topic: Water heater not igniting  (Read 106 times) previous topic - next topic
I'm leaving in about a week so I went through the RV and the water heater clicks and tries a few different times but it will not ignite.
I have propane going to the heater and I have propane going to the burners.
I blew out the L tube with compressed air and that didn't make any difference.
Where would you go from here?
ON EDIT
I took the igniter out and cleaned the electrodes and moved them just a little closer together and it fired right up!
Re: Water heater not igniting
You need to troubleshoot a bit.   Maybe start with the video here?
Water Heater Won’t Ignite
Can you see a spark and suspect it's not getting propane?   If so, your choices are a clog in the propane tube, an issue with the circuit board sending a signal to the propane valve to open, or the propane valve assembly itself.
I got it!
I cleaned off the electrodes on the igniter and moved them closer together just a pinch.
And boom ...it started.
Good move the igniter does double duty. It sparks and also proves flame. They get dirty and totally upset the apple cart. Always clean first.
Jon
