Topic: Power steering and power brake booster hydraulic fluid flush (Read 138 times) previous topic - next topic
Every 50,000 miles, our LD's power steering and brake booster fluid is flushed and the added filters to the return line are replaced.
Power steering filters | Flickr
With 145,000 miles and a lot of travel coming up, the job was done last weekend. Magnafine filters are now used to replace the older screen filters, with one each on the steering and brake return lines.
Amazon.com: 515554MagneticInlineFilter (3/8") : Automotive
The Owners Manual calls for Mercon V fluid, it was replaced with Valvoline Multi-Vehicle (ATF) Full Synthetic Automatic Transmission Fluid, which has a Mercon V rating. It is the same fluid used in the transmission and was recommended by the transmission builder.
Amazon.com: Valvoline Multi-Vehicle (ATF) Full Synthetic Automatic Transmissi...
