Topic: Demco/SMI actuator repair (Read 302 times) previous topic - next topic
The most common failure of the Demco tow brake unit is a broken cable on the air actuator cylinder that is mounted on the brake pedal.
Etailer now carries a repair kit that isn't too hard to use and a lot costs less than a new air cylinder.
Demco/SMI actuator repair | Flickr  Air cylinder repair
Air cylinder repair kit
https://www.etrailer.com/Accessories-and-Parts/Demco/DM56VR.html
Complete air cylinder...yes it's expensive!
https://www.etrailer.com/Accessories-and-Parts/Demco/DM6215.html
Re: Demco/SMI actuator repair
Flickr wants me to log in, Larry.
I repaired my Stay-in-Play Duo's air cylinder with this kit. If you have an older cylinder you may have a bit of trouble disassembling it. Once you have replaced the cable on an older cylinder you don't have the same problem with disassembly; removal, repair and replacement takes under a half-hour with the cable in hand. I carried a spare cable.
If you mount the cylinder too close to the firewall the cable develops a kink, and eventually breaks there. The second time the cable broke I moved the cylinder away from the firewall by reversing the mounting brackets. That should have reduced or eliminated the kinking. I don't know, as I've sold the car.
Mark H.
Former owner, 1997-8 mid-bath
Working now.  I am new to towing and also have the Demco unit so appreciate the info!
