Topic: Exhaust pipe ends (Read 862 times) previous topic - next topic
Exhaust pipe ends
I’ve seen where some of you have added stainless steel ends to your exhaust pipes. Are these available as DYI Add on or did you have the work done at a muffler shop?
Re: Exhaust pipe ends
I have seen them at Pep Boys and other big-box auto stores. Chrome tips are guaranteed to give you better mileage and more power.
I’ve thought about this. Aesthetically it would look nicer than the factory pipe but I found the pipe hanger and shield gets in the way and the tip would overhang too far out. Anyone have a link to one they used and liked?
Joe B.
Hi Joe; I had a friend with a used 2001. When acquired used in 2017, his exhaust pipe  had been bent up after an encounter with a curb (or something). I sawed it off shorter and put on this:  It might take awhile to find my records of where I got it.     Found it at Amazon.  Amazon.com: Dynomax 36484 Exhaust Pipe Spout : Automotive       RonB
edit:  Easy to put on.  The problem I had was after cutting off a lot of pipe, getting the stub round enough for this extension to slide on. Hacksaw, file, or better yet, a
         grinder. Had to remove some rust too.
"have the work done at a muffler shop?"
Good advise and that's exactly what I did years ago!   ;)
Hi Joe; I had a friend with an exhaust pipe that had been bent up after an encounter with a curb (or something). I sawed it off shorter and put on this:  It might take awhile to find my records of where I got it.  Dynomax I think.  Lots of places online, a random choice...36484 Dynomax Exhaust Pipe Spout - JEGS  RonB
edit: really easy to put on.  The problem I had was getting the stub (after I cut off a bit) round enough for this extension to slide on.
This must add at least 50HP! :D
Yea I have the same issue with my exhaust. Prior to our purchase the pipe met up with a curb and dented it a bit.
Joe B.
Yeah, I know chrome won’t get you home, I just thought it’d look a lot nicer than a rusty pipe. Especially right next to the door. Ron, who is Joe?
Dale from Downey.
Hi Dale: My bad!   I should have referenced both you and Joe, especially since you started this topic.   BrewersArcade; Joe Brewer in reply #3 and #5. He also has a damaged exhaust pipe. Pretty easy to hit curbs, campground marker rocks and such.  I liked this one because it is pretty short and a little higher.  Don't stand in front of it with the engine idling though.  RonB
I think the chrome tips would be a cosmetic addition to the vehicle's exhaust system. Perhaps someone could explain the reasoning. Thank you in advance for any information.
Sam
The diesel guys recommended trimming the chrome tip to an angle with the long side as the leading edge, some kind of scavenging effect.
2005 T/K
Hi Sam; Larry was joking about the power gain.  All between the ears!  But it looks nice. Any real power gain might be microscopic.   RonB
Yup, strictly cosmetic as Ron stated but I do think it gives a more “finished” appearance. Again, tricky part is finding a short enough and wide enough tip to not extend too far out and look like a goofy hot-rodded LD! :D
Ron, thanks for the link. Does anyone know the diameter of the factory pipe? 3” or 4”?
Joe B.
Well, I feel a little embarrassed that I missed the joke. Thank you for the clarification.
Sam
Hi Joe;  2.5"  that part I referenced would fit my '99 and did fit a 2001 pipe.  If you had a 'cat back' exhaust system like part of the Banks power pack or some other, you can realize more efficient flow and it can boost horsepower, or gas mileage if you can resist using that extra power.  Some exhausts can be 3' to 4" or even larger, but won't help much since most of the restriction is the valves, timing, manifold, catalytic converter or muffler.  Fiddling with factory provided parts usually just costs more money with no real return. If the factory could boost mpg that easily, they would have.  RonB
My exhaust measures 3” O.D.  I’m having trouble finding a short one to fit. One bonus though, now I know Brewer by his first name, Joe.
Be well, Dale from Downey.
Hi Dale;  This one is 6" long, slant cut, polished stainless with a 3" inlet and 4" outlet.  36505 Dynomax Exhaust Pipe Spout - JEGS   They have lots of sizes to fit all sorts of pipes.   RonB
