Topic: oil cooler lines (Read 133 times) previous topic - next topic
oil cooler lines
1995 Chevy 7.4L - Does anyone have a part number for these lines?  Or, any idea where to purchase them?
Re: oil cooler lines
With a nearly 30-year-old RV, new parts are not going to be available.  Your choices are to find them in an auto dismantling yard, fabricate a new set, or replace the hard lines with rubber oil lines, possibly mixed with sections of new hard line.
Occasionally, I see parts like this listed on eBay
Ah, the joys of owning an old RV
Hi Aschofer;  Welcome to the LDOG group.  I hope you'll find what you need here.  The cooling lines in your picture appear to be in good shape, other than needing cleaning. Can I assume you've tried a Chevrolet dealer, NAPA, etc?
   I did find some parts at RockAuto   1995 GMC G3500 7.4L V8 Fluid Cooler Line Connector | RockAuto, along with o-rings
   I guess I need to start replacing parts for my nearly 25 year old LD, or at least stock piling some harder to find parts for myself. It's hard to know what you'll need, until you need it.    RonB
Thanks Larry and RonB,
The lines are leaking oil up farther by the crimp where the rubber meets the metal.  I've searched everywhere and can't find a match.  Probably will have to have some made.
Andy
Hi Andy; If you can afford some downtime I know people who have had custom power steering hoses made for them in major city areas.  Also hydraulic pressure hoses, so these cooling lines with relatively low pressures might be easy to have made.  The metal parts might be re-usable.   RonB
They appear to be engine oil cooler lines, I would bet they might be available through NAPA. Might find a good pair at a salvage yard. Or cut the crimp ring off, shorten the hose and install a hose clamp.
Jon
