Topic: Series vs. Parallel (Read 181 times) previous topic - next topic
Series vs. Parallel
I'm installing solar (800 watts, 60 amp controller, 300 ah lithium). I'm trying to decide on the panel configuration. What are you guys doing: series, parallel or combination?
jor
09 27' MB
10  Suby Forester
Re: Series vs. Parallel
MPPT controller?
60a MPPT. I am leaning toward series-parallel. Seems like the best bet for shading situations and wire size. 4 200w panels.
jor
09 27' MB
10  Suby Forester
I've been using series-parallel hookups for years on various rigs with 400 to 600 watts of panels. It helps to minimize voltage drop, obviously. This hybrid approach also reduces the effects of shading on one or two panels, which can otherwise be a problem with an all-series hookup.
With that much wattage, series-parallel wiring is the best choice and it allows for expansion, most larger solar controllers allow 36 and 48-volt inputs. Upgrading to 4-gauge wires for the lead-in to the controller and then down to the battery is about the largest wire that can be easily fed down through the roof to the controller.
It will be interesting to see how this works with the 12-volt refrigerator in mid-winter, the time of year many have trouble keeping their batteries charged.
Well, we'll see! Right now I've got it running off a battery in my front room to make sure it works before I squeeze it through the window. I figure we could always add one more 100ah battery if need be. And of course, we still have the Onan! Thanks.
jor
09 27' MB
10  Suby Forester
