Topic: Latch (Read 359 times) previous topic - next topic
Latch
This is big!!!
Got tired of holding up the exterior frig door with my head. Installed a latch like the other compartments use. (told you it was big!)
jor
09 27' MB
10  Suby Forester
Re: Latch
I'm surprised the Factory didn't include a refrigerator door latch as standard equipment. Nice upgrade.
Re: Latch
I asked the last Newton (I forget his name) about that and he said the door was too flimsy.  He said it would get twisted if they used the stay-up latch.
I guess he saw too many people grab the door and try to pull it closed before releasing the latch.
Linda B
Green 2021 RB
2022 Ford Maverick toad
Re: Latch
That door is flimsy, no question. But it seems to me that any reasonable person would be able to handle it without warping it like a potato chip... and if bent, it's easily bent back into shape.
Re: Latch
I've always used these same latches inside the coach to keep and hold several keys!  Very easy and handy.
Kristin
1997 MB
Re: Latch
Good idea, Kristin, and you reminded me--I used one of those latches inside my first Lazy Daze (mounted upside down) as a clothes hook. It's so convenient, because when not in use it folds flat, so you don't have a hook sticking out into your living space.
Re: Latch
These below are stainless steel instead of plastic. I replaced my  original broken LD ones with them. They seem sturdy, but you will have to drill one hole as the pattern is different from OEM
5 Pack RV Stainless Steel Baggage Door Catch Square - Holds RV Baggage...
I try not to break the rules but merely test their elasticity.  '88 22RL converted to Rear Dinette
Re: Latch
I replaced all of mine with these: Latch
I really like the idea Kristin and Andy came up with of using these latches instead of hooks. I'm going to order a few more.
jor
09 27' MB
10  Suby Forester
Re: Latch
JOR, I've often thought about the exact same thing. What did you use to permanently seal the holes?
Jon
Re: Latch
I always use Dicor. Took off the batwing and sat dish. Filled the holes with Dicor. I've used it for years with never a leak. It's nasty to work with but cleans up easily with mineral spirits before it begins to set.
jor
09 27' MB
10  Suby Forester
