Topic: 2006 30IB Domestic Sea land Traveler replacing the toilet sprayer... (Read 133 times) previous topic - next topic
Hello! Does anyone know the exact model of a 2006 30IB toilet sprayer that was installed then? It seems like other people have have different ones to us..ours leaks when we flush the toilet or fill it with water..hubby says its hard to access behind the toilet to replace the whole line with sprayer, so he was thinking of cutting the line and just replacing the sprayer. If we can't replace just the sprayer after cutting the line, wouldn't be able to use the toilet! Thoughts? Thanks in advance!
2006 30' Island bed
Re: 2006 30IB Domestic Sea land Traveler replacing the toilet sprayer...
Or maybe even the exact model of toilet..maybe that could give us a hint.
2006 30' Island bed
Where is the leak coming from?
Here are some articles that might helps you narrow in on the leak.
Problem: Water drips from rinse hose and/or water around toilet base.
- The likely culprit is the vacuum breaker.  The part is difficult to get to - it may be just as easy to take the toilet apart and install new parts for the replaceable items, such as the vacuum breaker, toilet seal, flush ball and water valve.
The Lazy Daze Companion: Toilet Trouble-Shooting
and
The Lazy Daze Companion: Toilet Leaks
I just replaced the sprayer on our 2003’s Sealand Traveler 510. The hose is connected with a hose clamp, not hard to change.
https://www.etrailer.com/Accessories_and_Parts/Dometic/DOM88FR.html ;)
