Topic: Replace refrigerator (Read 361 times) previous topic - next topic
2006 LD 26.5 TK.  Prev owner put in a dorm refrigerator.  I ordered/received Dometic to fit original cutout.  Approx 24"wide by 24"deep.  It isn't coming in through the door.   Choice is remove window or remove passenger seat.  I read window removal works, but frig is 120lb and that's a lot of lifting.   Has anybody tried removing passenger seat (or even laying the seat back?
2001 26.5'  MidBath
Re: Replace refrigerator
Hi Mark;  The refrigerator will fit (carefully) through an opened window.  You don't need to remove the frame or anything else.  I'm not sure which window; a midbath owner will have to chime in here.  It will generally take two people.  I remember that previously people mentioned having heavy duty blankets laying on the window tracks to prevent damage to the thin aluminum tracks.   RonB
Open the midbath's dinette window--you don't need to remove it--and lay blankets or cardboard over the sill to protect it. The fridge will fit though. It's a two-person job.
While the removal through the window method has always worked for me, it is a two person job. If working solo, removing the passenger seat isn’t difficult, just four Torx-head bolts and one electrical plug to remove. The seat is heavy too .
After removing the old refrigerator, it would be the time to add insulation to the  enclosure.
MBIRNBAUM,
In case you haven't already found it, here is a thread that describes our experience:
Dometic Refrigerator Installation
Here is the specific message, including photo, of how we removed the dead fridge, and then moved the new fridge, through the dinette window:
Good luck.
Jim
Jim & Sue
Formerly owned: 2011 27' MB, Sidra
