Topic: Sewer pipe storage  (Read 513 times) previous topic - next topic
Sewer pipe storage
Saw a few people on the Internet use a 5x5 vinyl fence post and some vinyl 4 inch gutter to create a sewer storage.
On the lazy daze there is virtually zero space under the coach to add such storage, but after gazing at the coach for a while I noticed a possible mounting location within the triangular “skids” in the rear.
sadly the skids don’t fit a 5x5 fence post….but with a cut down the bottom the post can be squeezed into the skids. I riveted some material to the edges of the tube to bring it back square. Unless you’re laying under the coach it looks like a perfect fit.
I drilled a few holes in the skids and cut some access in the fence post to bolt it in place.
The gutter is a perfect tray, holds 2 sections of sewer hose and pulls in and out nice and smooth.
Capped one end and capped the other end with some shock cord to hold the cap in place.
Obviously the width has to be just right to avoid possibly rubbing the storage on the ground at a bump, but I think I’ve got it dialed in to be completely out of the way.
2000 RB
Re: Sewer pipe storage
Is this for additional sewer hose storage? We use the storage that came with the LD and have an extra piece in one of the compartment just in case we need a long one.
Steve and Jill, Steve posting
1999 26.5 Mid-Bath
Yep,
I rarely use full hookups so the short original sewer hose is adequate, but the 1-2 times a year I have full hookups it’s nice to have plenty of hose.
2000 RB
What a great idea. Nice job.
jor
09 27' MB
10  Suby Forester
Great way to store extra sewer hose.
For fishing poles, a piece of 4" ABS pipe, with 2 caps can be installed under the rear bumper, Glue one cap shut and the other cap s drilled for a large bolt, also drilled to accommodate a lock.
Fishing pole storage | Flickr
Some folks simply put the extra hose in a trash bag and place it inside the faux spare tire cover. It’s a good use for that otherwise useless space.
That would work good, sadly the RB has a tire there haha
2000 RB
That would work well, sadly the RB has a tire there haha
Most floor plans have the spare tire located behind the rear cover.
Our 24' FL has enough room to add a 50' garden hose for use with the macerator pump...and that's it.
Recently I had a problem inserting the sewer hose back into the built in storage tube under the coach. This had not been a problem until now. I finally had a chance to get under the coach and inspect the storage tube which had no visible signs of crimping. Unfortunately the visual inspection is difficult because it is behind framing and storage compartments.
Instead of dealing with this issue further I remember another LDO Forum member (Cor2man) had installed a storage container behind the rear bumper and I thought this was a good idea.
I started digging around my shop and found a 10' piece of schedule 40 4" PVC pipe. This too fit inside the skid shoe framework as Cor2man's tray did. I cut the PVC to 86" and glued screw in cap fittings on each end of the pipe after the pipe was in place. To secure the pipe in the 1/4" steel framework on both sides of the pipe I drilled a hole to fit a #6 X 1/2" self taping screw through. I also cleaned the steel that would come in contact with the pipe and applied strips of 1" VHB tape. The wall of the pipe is 1/4" so the screws didn't penetrate to the inside surface. To limit the travel of the hose inside the pipe I screwed a #12 X2 1/2 " self taping screw at the midway point in the bottom of the pipe. This allowed me to carry two hoses accessible from each end of the pipe. I drilled a hole through the cap fitting and housing, threaded it with a 1/4 (20) tap, and inserted a 1/2" thumb screw to secure the cap in place while driving.   I have used the Prest-to-Fit hose systems for many years because they are so easy to configure and use. The second hose can easily be added to the first hose with a coupler for additional length or as a replacement for the first hose.
2004 Born Free 26'
1998 Beaver Patriot 33'
1992 Barth Breakaway 28'
1982 Fleetwood Jamboree 23'
1982 Dolphin/Toyota 22'
Another great idea to knock off! Thanks, Mike.
jor
09 27' MB
10  Suby Forester
Nice upgrade, Mike!  I don't use the LD storage tube (except to mount the outside temperature sensor in) so that is an upgrade I am interested in.  Bookmarked for future reference.
Great tutorial, done on a beautiful RB, up on a beautiful RV-capable lift, in a fantastic shop, owned by two wonderful people!
Like Greg said, I'm bookmarking this one. I dislike that storage tube, and dislike storing the extra Prest-O-Fit hose in another storage compartment.
Thank you Mike!
Jason
Jason
2003 Rear Bath
"Razor Crest"
Jason, you don't live far from us and the job would be easier to do on our lift. You are always welcome to stay over on our RV pad. We certainly enjoyed staying at your place while visiting Gainesville recently.
We hope you and your family have a good holiday season,
Mike
2004 Born Free 26'
Thank you Mike!
It would be nice to visit again, the family would love it. And your guidance alone would make the job easier...the lift would be a nice bonus!
Jason
Jason
2003 Rear Bath
"Razor Crest"
Never had an issue with the sewer hose but did need a place to store fishing poles.
In 2003, I installed a3” ABS pipe and fittings, along with a locking pin that worked fine for the application.
