Topic: Slider Drawer Under Dinette (Read 344 times) previous topic - next topic
We've tried to store stuff in the compartment under the dinette but it's a pain. I installed a 21" slider drawer which looks like it will work great. I sawed an access hole to get to the area behind the slider but decided against using it as it's awkward to get and there is very little room anyhow.
Here's the drawer I used. Home Depot, 70 bucks: slider drawer)
jor
09 27' MB
10  Suby Forester
Re: Slider Drawer Under Dinette
I like the way you think!
Idea soon to be stolen.  :D
My wheels:
2012 Jeep Liberty
Very slick!  Nice work!
Ron S
Ron and Linda
Ada Michigan
Sweet! 👏🏻
"We've tried to store stuff in the compartment under the dinette..."
Neat work, JOR!
I installed a very similar sliding shelf in a cabinet under the oven on my 30'IB. Accessing items stored there are now quite easy to reach.   ;)
We built a drawer there also.  Took awhile to figure our where the thumping noise was coming from after that. Finally found the drawer sliding out and bumping into the door.  We ended up putting a latch on it to hold it in closed location on travel days.  Simple hook and eye on the edge but it kept it from rolling back and forth and bumping the door.
Sand Castle (Theresa & Everett) Surfside
01'  26.5 Mid Bath,   2018 31IB
Michigan born and starting to explore the US with my  spouse and our furry friend. Enjoying joining LD group rallies.
Good tip. I'll keep an eye on it and be prepared with a latch. Please post a photo of your latch so I can knock it off. Thanks.
jor
09 27' MB
10  Suby Forester
We tend to work on the KISS principal, simple and low tech. It works as a pantry drawer. The drawer is deep enough that nothing falls over the sides. We do lose some space but at least I don't have stuff lost in the back.
Thank You Jor and Theresa & Everett for your solutions.  We have a similar situation with our under dinette seat drawer in our 98~MB.  We installed a box slider drawer under the dinette seat and left the OEM door as installed a couple of years ago.  Soon after driving our 98~MB as we made turns the door would open and drawer would slide in and out as we turned.  We bunged it right away which has solved the problem so far but this fix is an unfinished job.  We have been looking for an easy latch solution.  The drawer slides are self keep closed models but did not do their job.  The hook and eye fix here shown could work but we would prefer a latch on the door so you don't have to bend over or crouch to get close to latch and latch the drawer.
When we installed the drawer under the dinette seat the exterior battery compartment on this model sticks up so drawer must be shorter to fit and leaves open space behind it.  We cut a doorway into the wall by the door step well to access that space.  It makes a great space for shoes etc, actually we put items that we can reach easily from the entry door while we are outside like our electric dog bone adapter etc.
                            Karen~Liam
                               98 ~ MB
                                 NinA
http://www.lazydazeowners.com/MGalleryItem.php?id=4549
http://www.lazydazeowners.com/MGalleryItem.php?id=4550
Stepwell Cubby - http://www.lazydazeowners.com/MGalleryItem.php?id=4551
1998 ~ MB  WanderDaze
Hi Liam; Just some musings about what I would do.  Put some cushioning foam on the back of the compartment door to hold the drawer in.  Then improve the latch using the same type as other doors my rig has, used by Lazy Daze.  This is that type. A bit of door surgery but it would match the type already there. RV DESIGNER COLLECTION Postive Catch | 31-1462 | by PPL    I was considering taking off the door hinges and making the door into a drawer front.  I've always liked these locks because they provide a visual clue to show that they are locked.   Caravan Door Lock RV Cabinet Push Knob Button Lock - topseeklocks.com                                 RonB
Thanks Ron, That's the basic idea I was playing around with.  I also got these for our two Kitchen drawers and only need two so I could use the extra one on that under dinette door?
Karen~Liam
  98 ~ MB
    NinA
Encell Set of 3 Push Button Lock for RV Motorhome Boat Cabinets - - Amazon.com
Hi Liam, If you already have them in another place, it will be easier for all if you stay with the same type of catch.  RonB
The main issue is that those latches I have will require some setup to drill/cut and fit them in the deep top rail of the door.  Fortunately all the top rails in the drawers are the same as the door.  I will post it when I get time to do it.
     Karen~Liam
       98 ~ MB
         NinA
I have used this push to open latch for several years without problems to keep a tool box from pushing the door open
Mc-37 Non-Magnetic Touch Latch Safe Push Latch Black - Cabinet And Furniture...
I'm likin' these latch suggestions. The deeper drawer is also intriguing.
jor
09 27' MB
10  Suby Forester
