Topic: Interior/bath wall construction question (Read 321 times) previous topic - next topic
I want to mount a couple coat hooks to an interior wall in our Twin King 24.
In between the paneling-like wall (the blue tape is attached to) and the fiberglass shower on the other side, there appears to be about 3/4" of space.  Using a stud finder I found what appears to be solid wood backing that runs vertically (floor to ceiling) where the blue tape is in the attached picture.
My plan is to mount the coat hooks to a piece of wood, then screw that wood to the wall where the blue tape is in the picture.
Can anyone tell me whether there are indeed wood studs/stringers/blocking (whatever you want to call it) running vertically between the wall board and the fiberglass shower on the other side?  Also, any wiring/plumbing running in that area?
Thanks for any assistance.
Alan
A 2021, Twin King 24'
Re: Interior/bath wall construction question
Best thing is to take out your kitchen drawers and you can look up that wall some.
In general you are right - wood framing in that wall - I forget exact where and direction though.
We have an older TK - ours only has plumbing in that wall and it is easy to trace that to avoid it.
We use command hooks a lot - they hold up well, no screws needed, and easy to move when you want to change things.
I used to be pretty casual about putting screws into my Lazy Daze's walls--with or without studs behind them--and I never had a problem. But I've been hanging my jackets on large Command hooks for years now. I'd try that before I'd make holes in the walls.
I think you'll really want a pantry in that space, the depth is perfect for canned goods etc.
2015 TK
A pantry cupboard is definitely worth thinking about. Coats can go almost anywhere, but that location is ideal for a pantry cupboard, and there's no really other place to put one in a twin/king. It's not hard to build, either. You can find plans on this page.
Going with the Command hooks.  Thanks!
That space is too precious in a TK for coats.
Here’s the pantry I built last summer on the road:
     Yet another TK pantry build
Since that post, added a leftover piece of steel attached with a magnet, for use as a door pull (the magnets I used are super strong) and as a coat hanger.   So you can have both a pantry and coat hanger.
Dave
2017 TK
I like Dave's concept: build the pantry cupboard and then hang your coats on its door. It's only four inches deep, so  even with a coat hanging on it, it won't obstruct the passageway.
Went all last summer and two weeks this year not thinking about hanging a coat there, when my wife joined me, she suggested hanging a coat there. Doh - didn’t occur to me at all.   I’ll add another next hardware stop.
I do lose a third of the rear view mirror when when a coat is hanging while driving.
Personally don’t mind as I use the side mirrors more and if I really want a view behind, the rear camera gives me more detail.
Dave
2017 TK
Similar subject, different question.
LD put a clock in the perfect place for hanging a paper towel holder.
I'd like to remove the clock, then screw in a paper towel holder under the cupboard.  There is a gap of about 1" between the bottom of the cupboard and the interior "floor" of the cupboard, which appear hollow.  Both surfaces appear to be made of about 3/16" plywood.
Anyone know whether there are any wires in there?
You could use over the door hooks and move them where you want them?
     Karen~Liam
       98 ~ MB
         NinA
Amazon.com: 1st Choice Pack of 2 Over-The-Door Hook, White, W, 2 Count :...
1998 ~ MB  WanderDaze
