Topic: Propane Tubing Inspection (Read 106 times) previous topic - next topic
Doing some annual maintenance/ inspections and today is my “under the rig” day.  One of the items is tracing out the propane lines under the coach so that I can perform a leak check on any mechanical joints discovered.  So far I’ve only found two elbows, both on the drivers side;  one near the black water tank and the other near the fuel tank.  Anyone know of any other ones that I may have missed? This is a 2017 MB.
Re: Propane Tubing Inspection
Update, found a third elbow, just forward of the rear passenger side tires.  :)
A good way to check for leaks is to use a manometer connected to the regulator.
It's also a good way of checking the propane regulator pressure. It should be 11 inch/H2O.
Anyone test their gas pressure?
Larry, would this be like a leakdown test?
What’s an acceptable leakdown(if any)?
I try not to break the rules but merely test their elasticity.  '88 22RL converted to Rear Dinette
