Topic: Engine block ground location (Read 99 times) previous topic - next topic
Yes, another question.
 I have not found the suggested location of the mounted ground bolt for the engine block in the E450 V10 owners manual.
Curious if anyone knows the likely location, I assume it is on the passenger side but I was not sure.
Will be checking of this after the snow storm passes thru on Friday.
Is it advisable I am sure to disconnect the battery prior to investigating the ground connection to the frame.
Thanks again for your patients, Kimberley
2000 Mid Bath
Re: Engine block ground location
Disconnecting or reconnecting the engine block to frame cable does not require lifting the battery negative cable. If you work on any connections in the positive circuits, it might require first lifting the battery negative.
