Topic: Engine Insulation Replacement (Read 208 times) previous topic - next topic
Many years ago, Larry replaced the rat-destroyed insulation in my engine compartment.  Recently, it came loose and I spent mega bucks for a local shop to pull the doghouse and re-install the insulation.
Returning from Moro Bay, my feet and legs roasted on the 175 mile trip home -- hotter than when I took it in for repairs.  Before I approach the local shop with demands and/or accusations, I'd appreciate (1) some advice for a preliminary approach to their tech writer; and (2) some simple information on which side should be "up"!  Kidding aside, in which direction should the aluminum side face?  And last, is there anything else I can do to eliminate the very uncomfortable heat at my feet.
And before you ask, yes, the fan was on, and the h/c switch was set on cold.
Thanks for your help,
Lorna
2003 RB
Re: Engine Insulation Replacement
Geez, I wonder if the doghouse is not sealing properly. The gasket could be misaligned or a latch not secured. The insulation job is pretty straightforward so I wouldn't think it would be the issue. Here's a few photos of mine to give you some reference. Under the carpet the doghouse has a piece of insulation on two corners. Inside the fiberglass structure there is an insulation insert. When I did mine I just added a layer of automotive  insulation/sound reduction material to the insert and put it back together. Good luck to you.
jor
09 27' MB
10  Suby Forester
Lorna's LD must tasty because the rodent can't resist nibbling on it and using it to pad nests.
Besides removing insulation from the doghouse insulation they like to remove insulation from the driver's side firewall, next to the accelerator. This is the cause of the 'hot foot' syndrome.
Rat damage
Rat damage | Flickr
Ford wanted a lot of money for a new insulation kit and a long lead time, a local speed shop provided the replacement insulation used to repair Lorna's LD. It was secure with high-temp spray adhesive and existing metal tabs...this was until the next time it happened.
Cool-It Mat Thermo Tec | Thermo Tec
Oh, the rats. That sure explains it. You have my sympathy. I have lots of experience with those little critters. I use a regimen of lights, peppermint and sonic devices along with frequent inspections to keep them at bay. Good luck to you.
jor
09 27' MB
10  Suby Forester
OK Larry, so is there a solution for "hot foot" syndrome - or: southward moving hot flashes)!!?  That describes my most recent malady!
Lorna
2003 RB
