Topic: Oil in coolant 1997 V 10 (Read 99 times) previous topic - next topic
If you happen to have this problem....dont default to a blown head gasket ....Especially if you have never had an overheating issue.. In my case it turned out to be a leaking oil cooler...It is between the oil filter and the engine..It has 2 coolant hoses connected to it...If you want to test...just connect the 2 coolant hoses together with piece of pipe and run the engine....if the cooler is bad..you will see oil start to drip from the water hose connections of the cooler...122 dollar repair..easy to do yourself...
1997 Rear Bath
