Topic: Factory roof sealant? (Read 296 times) previous topic - next topic
This is on my '88 22'. Could it be original? Looks pretty bad, I know.
 Should I use Eternabond tape? or use the original stuff?
I try not to break the rules but merely test their elasticity.  '88 22RL converted to Rear Dinette
Re: Factory roof sealant?
I'll let others answer your question but just so you know, the original sealant for your roof was probably Parlastic.  That was abandoned at some point for a better sealant whose name escapes me.
If it looks greenish yellow (ormaybe under some grime) and Thick -
1/4” or more and fairly hard like plastic with bigger cracks), I think that was  original.  The first picture looks like it  might be original, the second one looks like dicor unless it  just has a lot of dirt/grime on the original.
We had a couple spots with what we thought was the original (I forget where, maybe around an antenna) and I was amazed how well it held up but it might not in area more prone to leaks (roof seams etc.).  The top was all cracked Al it when you got down about half way it was in very good shape.
Dazed
If you haven’t browsed the instructions for getting the most from our forum, you may have missed this guide on “Searching” for topics of interest. Gaining skill in searching will really help you answer your questions on routine topics like roof resealing.
Here is a link to the Search instructions guidance.
Search Function Tips/Instructions
- W
Warren
2019 MB “Dream Catcher”
Jeep Wrangler JL
That is definitely is the original sealant.
I suggest completely removing it and resealing with Eternabond or a polyurethane. Eternabond would be my preference.
A vibratory tool with a sharp blade is the best tool for the removal job.
Thanks, I used that tool successfully, and got down to bare metal quickly. Amazingly, the original Parlastic was still flexible after 35 years(I'm sure it was original to this Coach)
Now I'm waiting for a few sunny daze to prep for E-Bond
Thanks, all for your helpful suggestions
