Topic: Installing a digital thermostat  (Read 150 times) previous topic - next topic
I installed this one in my 1995 but my memory fails me as to where the red and white wires go.
Help needed.
Thanks
Re: Installing a digital thermostat
I just installed a similar heat only digital thermostat last week, came with specific instructions for two wire heat only systems, connect to W and RH. (White to W, Red to RH)  worked just fine.
I believe your C says optional with batteries, unless you’re adding a third (powered) wire, just connect up White to W and Red to R.
     edited by RonB to add a link:  Emerson 1E78-140 Non-Programmable Heat Only Thermostat for Single-Stage Systems
Dave
2017 TK
Thanks Dave.
As usual I was over-thinking this.
Thanks again.
It works!!
