Topic: Paint supplier and paint codes for LZ (Read 321 times) previous topic - next topic
I have 2016 Mid Bath, color is white/light grey/charcoal.
I called the factory, it seems that it was closed. I am looking for paint supplier and paint codes for my white color. If any info on the other 2 colors code, will be wonderful. Please let me know where I can buy, what I should buy.
Thanks
Wendy
2016 Mid Bath
Re: Paint supplier and paint codes for LZ
I have a 2016 Mid Bath, color is white/light grey/charcoal.
I called the factory, it seems that it was closed. I am looking for a paint supplier and paint codes for my white color. If any info on the other 2 colors code, will be wonderful. Please let me know where I can buy it, what I should buy.
AFAIK, The Factory never released the paint codes for newer models. The older models' codes are obsolete and unavailable.
Your auto painter will need to match the colors. Auto painters usually have color-matching books for this purpose..
The paint is a two-part polyurethane, make sure to use this type of paint to match the existing.
You can also easily remove exterior hatch covers and take them to an auto paint store for color matching.
Wendy, the paint code label for my 2017 MB is on the driver side door jamb.  Your white code will be the same as mine but the colors will be different since mine is blue.
Wendy,
I believe the simple answer to your question is that the white paint on the Ford van portion of your Lazy Daze is known as "Ford Oxford White". Lazy Daze used the same color on the body that Ford used on the front cab, doors, and fenders.
The only exception that I am aware of was a year or two in the late 1990's or early 2000's when for some unknown reason, the white portion had a greenish tint to it. Ford always uses the same color for the van chassis to simplify production and for the aftermarket upfitters.
Steve K
Steve K
2003 Mid-bath
Well, having a 1998 with the greenish white paint...I thought the Oxford white would work, but thankfully saw your post! Still have to figure out what color to use, for touch ups.
Wendy, we have a 2002 Lazy Daze. Several years ago I wanted to touch up/spray paint an area or two near the front wheel covers of our LD, but had no idea what color codes to use. I called around to a few stores-all of them said they could  not help. HOWEVER, I finally found an auto store near me (can't remember the name) that looked up the paint code and mixed the paint for me. I got two different spray cans, which didn't even cost that much. They matched perfectly. My point-there are stores out there that will take the time to help out. Best wishes.
2002 RB
I will also try that with the greenish white Ford color. Thank you!
