Topic: Sewer hose suggestions (Read 404 times) previous topic - next topic
Mine always seem to get holes near the connector.
What's the thickest and best brand you've experienced?
Thanks
Re: Sewer hose suggestions
We found Valterra brand Dominator is more durable than other brands or even other Valterra styles.
After trying several different brands over the years, the best I've come up with is the Valterra "Dominator". (The idea of being dominated by a sewer hose is so bizarre that I have to wonder what drugs the person who named it was taking.) Both the hose and its fittings are very sturdy. And unlike many hoses I've used, when I collapse it, it stays collapsed. It only pulls out to the length I want.
When I'm at a dump station, I don't want my hose any longer than it needs to be. If it sprawls all over the place, that just makes it harder to deal with--especially if I'm in a situation where I'll need to "milk" the hose to completely empty it. Many hoses will start out collapsed, but as soon as I open a dump valve, will expand out to their full length. The Dominator hose doesn't. It stays just the length I want.
With that hose and a Valterra HydroFlush elbow for back-flushing the tanks, I have a setup that works well for me.
(Afterthought)
However, those wiser than me have pointed out that this hose's end fittings are too large to fit in a Lazy Daze's storage tube, although they fit my Airstream's storage tube. Sorry about that.
Andy,
I would like to get this hose for my 2017 MB, but I'm wondering if the red end cap would prevent it from going into the storage tube?
Glenn & Joan Lambert
Redford, MI
2017 27' Mid-Bath
That Valterra hose and connector will not fit in the LD (standard sized) tube; at least, not in the 2003 that I had. The only fitting(s) that worked were these:
Amazon.com: Valterra F02-3305VP EZ Coupler Red 90° Sewer Adapter and Thread...
I carried an extra set of fittings and two hoses of different lengths; the twist-on fittings work on a standard 3" hose without already attached fittings. If one is concerned that a twist-on will leak, a tie wrap works just fine. I used this setup for many years and never had an issue; the red Valterra hose is no longer available without the attached fittings, as far as I know, so I used a medium weight generic hose. The linked-above fitting set may be hard to find now; Dometic bought Valterra a while back, and the product line-up has changed.
As ever, YMMV.
Andy,
Caps and fittings on 3" dump hoses usually do not fit into the hose Factory storage. Some owners add a 4" diameter ABS drain pipe across the rear of their LD, near the rear bumper.
Below is an example of a 3" ABS pipe, used for storing fishing poles. Upgrade to 4" ABS pipe for dump hose storage.
Fishing pole storage | Flickr
"I'm wondering if the red end cap would prevent it from going into the storage tube?"
Good point, Glenn. I didn't have the Valterra Dominator hose when I had my Lazy Daze; I'm using it with my Airstream, which has a length of rigid sewer pipe beneath the rig for hose storage.  So Joan's always reliable advice supersedes mine. Sorry for the bum steer!
For the record, I just measured the female (larger) end of the Valterra Dominator hose, and its maximum diameter is 4-1/8". So you'd probably need a 4-1/2" to 5" storage tube.
We’ve used the Camco RhinoFlex hose for years. I’ve not experienced any holes or other problems with it. To fit the hose into the factory storage tube, I remove the hose fittings and insert the bare 15’ hose into the storage vault. I rinse and store the hose end fittings in a container in my storage locker dedicated to all things related to sanitary dumping.
Amazon.com: Camco RhinoFLEX RV Sewer Hose Kit with Swivel Transparent Elbow...
Warren
2019 MB “Dream Catcher”
Jeep Wrangler JL
We use a 15 mils Camco hose, it is very similar to the stock hose LD provided and has been adequate for our dumping needs
It gets replaced every 7-8 years and fits fine in the Factory storage tube, with the bayonet fitting attached on one end.
Amazon.com: Camco Durable High Tensile Strength Vinyl Sewer Hose with Steel....
There are several 'deluxe' hoses available, overkill, IMO, for our needs. We never leave the hose hooked up, it is only used to dump when the holding tanks are full, eliminating the destructive effects of the sun and abrasion from moving around.
It works for us.
"We never leave the hose hooked up, it is only used to dump when the holding tanks are full, eliminating the destructive effects of the sun and abrasion from moving around."
Same here. There are lots of reasons not to leave a sewer hose connected, even when camping in one place for weeks. Small rodents, for example.
Like Glenn and Warren, I wanted a sewer hose that would fit in the Lazy Daze sewer hose storage tube. I needed to replace the LD supplied hose and I also an older and longer hose for home use. (Yes, I have a sewer clean out at home that I use a few times per year). I ordered the twin pack of Rhinoflex 10'  sewer hoses complete with fittings. The problem was, the hose with fittings would not fit in the hose storage tube. And to remove the fittings, I had to cut them off. Grrrr
To make one of the hoses fit in the LD storage tube, I replaced one end with a straight hose fitting from Prest-O Fit;  attaching it with a large screw clamp. The Prest-O Fit Blueline fitting is usually just inserted in the hole at the dumpstation but will easily attach to other couplings if you need to. The other end of the Rhinoflex now has a Camco Easy Slip straight hose adapter which has two grooves that lock on the LD's dump valves. It DOES  fit inside the door of the storage tube. No need to remove and store any attachments. The Camco Easy Slip comes with a built in twisting clamp to attach it to the sewer hose.
The Rhinoflex hose seems to be working out well. It is very flexible and collapses easily for storage. I would buy it again but the key to making it work for me is making it fit in the storage tube.
Steve K
Steve K
2003 Mid-bath
When the Blue hose which was in the hose compartment when we bought our 98~MB failed due to being frozen in the storage tube and half of it stayed in the tube till thawed.  We were stuck with only 6ft long so a replacement was needed right away.  We bought the Valterra D04-0057 Heavy-Duty Quick Drain Hose - 15' and used the fitting from the old hose with a hose clamp on the outside.  This fitting is most like the Valterra T1024-2 Black 3" Straight Hose Adapter.  This setup fits in the storage tube but does not have a finished end on the output side, its been working for 7 years now.
          Karen~Liam
            98 ~ MB
               NinA
1998 ~ MB  WanderDaze
